Re: Moby **** Trinity (3 X Ostar, 3 X Cree, 3 X Shark)
adirondackdestroyer, good question.
The difficulty is assessing the cost is the host. I'm guessing this particular host was well over $500, before any extension tube accessory or 18 AA holder.
Parts cost for the actual mod, including the pretty exotic low volume CNC milling of the 9 oz. heatsink approaches that figure as well, not including my build time of 8 - 10 hrs.
Then the proper cell solution, which isn't the 18 AA I'm temporarily running it on. LuxLuthor will work his magic (thanks LL), and 12 Emolis with some expert pack wiring won't come cheap either, but worth every penny.
So add all that up and you're well into 4 digit territory. Prohibitive? Yes. Worth it? That is all up to the beholder, in this case Griff. I certainly hope he thinks so, and after he receives his light back I hope he will post impressions, good or bad.
I will build a few more with hosts I have or am having made, probably some with just tri-Ostars as well. They likely won't be as fancy as this one, but also should be more reasonable. But regardless of the particular host, cell solution, and bin of LED, they will all probably be close to 4 digits.
