Hack On Wheels
I'm going to help a friend mod his 6D Mag and he would like to keep it looking stock from the outside. I guess its also worth nothing that though I'm assuming the switch still works fine, the guts of the light aren't in great condition.
The budget isn't big at all, say $50, but I'm sure if something awesome enough was suggested then the budget could stretch.
The best option for the head setup seems to be a fairly standard P7 or MC-E, using the stock reflector for starters and probably with a heatsink like the H22A one.
I've also read over a bunch of options for driving it, but I can't decide on what makes the most sense value-wise. This light will be built to pump out a lot more light than something with a single die emitter, so running the emitter at its max rating (700mA per die) would be good. If it can be used practically as well, ie. having a lower mode or modes, that would be a bonus.
However, the really big dilemma for me is deciding what to do with the space for 6 D-cells. As a fairly cheap solution, I was contemplating a simple 6 AA holder slid into the body with some foam or something to suspend it. This would have a connector of some sort wired onto it and there would be another connector wired into the Mag switch for this option. The upside would be that it could use AA cells which are pretty common and it would be much lighter I imagine than using a full complement of D cells. Its a lot of space to fill and play with, so any thoughts would be really appreciated!
Thanks for reading!
Thanks for reading!
