Managed to find some time tonight to mod my BA Lioncub to an SSC P4... Bin on the P4 is USX0I... Instead of modding the McR20 reflector, I'm using a standard/unmodded IMS SO20XA reflector which seems to work alright... The beam isn't perfect, but I just couldn't be bothered to mod a reflector after putting in the SSC..
Anyway, I'm comparing it with my Black HA Lioncub #008/100 which still has the original Luxeon star in it... I'm not sure exactly what bin is in it, but I'm guessing either a TX0J or TX0K. To make sure I'm comparing apples to apples, both Lioncubs are powered using 18650 batteries, with exactly the same voltage (4.15V), and I've switched the reflector on the Black Lioncub back to the IMS SO20XA reflector as well.
Here are the Beamshots:
Black HA Lioncub #008/100 with Lux III (1/15sec, F5.6)
BA Lioncub modded with SSC P4 Bin USX0I (1/15sec, F5.6)
I just measured the current from the battery, and it's only drawing 0.92A, so I think the Vf on this particular emitter should do just fine in the LionCub...
Here is a picture of the modded Lioncub head... You can see that the yellow basically fills the whole reflector, which means that it is pretty much in focus without modifications...
