PCC
Here's a little project that I've started and hope to finish in the next day or so. It's an inexpensive Dorcy spotlight that runs on a 6V lantern battery. The PR flange bulb that is in it is terrible. It's not very bright even with a fresh 6V lantern battery. I changed it to the halogen bulb from my Mag 3D and it was both brighter and the light is whiter, but, being incandescent, it'll drain the battery faster than I want so I decided to convert it to LED with a low budget. How low? Try $0! The LED itself is a Luxeon that I pulled out of my 2D MagLED module when I upgraded the emitter to a SSC P4. I'm going to hook up a small potentiometer that I already had inside the case set to a value that doesn't max out the emitter to extend the life of the battery and to minimize heat build-up from the LED for use during power outages.
Here is the gallery for the pictures. There are a few more pictures than shown here.
Here are a few pictures of the spotlight as it came from the store.
I started by milling a heatsink and mount for the LED out of a piece of scrap 6061 aluminum that I found in the garage. Here are a few pictures of it after the milling operation and test fitting the LED on it with the reflector assembly. Sorry that it is a little rough but it'll be inside the light and no one will see it so it's not a big deal.
I need to mount the emitter to the heatsink and figure out how to do the wiring without shorting the thing out :poof: I'll work on that tomorrow and post more pictures and updates after I some more progress on this. Stay tuned!
