More throw for Malkoff M60
morrisgarages
Hello guys! I just purchased a Malkoff M60 a couple of weeks ago for my surefire 6P. I'm fairly happy with it (good balance) but I want more throw out of it. Is there any way for me to get more throw out of my M60? What's the best thrower drop-in for my 6P out there? I want something that would run as long as my M60. Thanks guys and I hope to hear from you soon.
Good question. I like my M60 for the good balance as well - if you're trying to stay with LED's, I don't know if you will find substantial improvements while keeping the P60-type form-factor. I gather that some of the incan drop-ins could out-throw the M60 but of course you'll be loosing the runtime you're trying to keep. I'm guessing someone could cite something out there which somewhat outhrows the M60 but I'm also guessing that the difference won't be dramatic in actual use?
My only suggestion would be a LED tower in a 2.5" SureFire KT1 / KT2 turbohead in your SF 6P (check the link in my sig, it crushes the M60 I'm using for a comparison - in particular, look at the 'underexposed' beamshots later in post #1 to get a good idea of the relative spot intensities), or maybe an aspheric lens mod?? Perhaps others may have a better idea? :shrug:
(For a bump in capacity (you do cite runtime being of interest), you might want to think about the SF 9P/G3/C3, especially if you're using a rechargeable configuration - you're talking about ~double the capacity (2x17500) in the slightly longer bodies.)
the beam pattern of the M60 is not adjustable and changing voltages won't make it more or less powerful. There is no add on lens or part that you can use to make it work better for throw, it is what it is. Its meant to be a medium thrower. If you want a stronger thrower that drops right into a Surefire 6P type light (a p60 pill) then you want the latest Dereelight module with a smooth reflector. That will give you a tighter beam pattern to throw more light down range without having to buy any fancy schmancy "turbo" heads that may or may not fit and adapt to your original host.
Flashcrazy can help you out on the Dereelight modules.
You could try to soften the black potting material using some heat, carve out the softened material to expose the driver, remove the driver, and replace it with something that delivers more drive current to the LED. Modest overdriving could give you more output. Watch out for too much of a good thing, however, which can result in excessive heat and reduced output vs a lower drive current.
You can use any high powered 3rd party drop in like those you find on Dx, but use a SMOOTH reflector. I didnt think the difference would be much. Boy was i surprised....
Malkoff on left, Superbright R2 (rouhgly 1A drive) with Smooth reflector
Crenshaw
If you are handy, you can build an LED Turbo Tower using the Netkidz tower kit (for sale currently in the B/S/T forum). Top it with an XP-G R4 or R5 on a 2mm thick, 10mm MCPCB. Drive the XP-G with a 17mm, 3xAMC7135 driver board. Install the tower in a SureFire KT1 or KT2 TurboHead and mount the TH onto your 6P. Run the light using 1x17670 Li-ion. My guess is that you'll get both more lumens and a much brighter hot spot vs the M60. Tradeoff is the larger TH size vs the standard 6P bezel.
See this thread for example.
surefire 6P
Quoted from the SF website:
KT1-BK 6V TurboHead Conversion
Fits:
Z2, C2, 6P, D2
It's not rocket science. :duh2:
Crenshaw (being his normal helpful self), thanks for the pics, very good illustration - as usual, pictures are worth a thousand words. :twothumbs It always helps for people to post on topics they have experience with.
I'll be MrGman's backup on this one.
I have both an M60 (in a 2x18650 body) and a Deree drop in.
I prefer the M60 most of the time for it's brightness and especially for it's "just right" spread for 99% of the times I need a light.
But the Deree is a narrower, better thrower for when I want to see what's out there in the woods.
So for the easiest, no screwing around options, get the M60 and a Deree drop in both, and you'll have your bases covered.
Yep if throw is the important thing a Deerelight R2 drop-in with a smooth reflector is going to make you happy.
Unless you are willing to move into a fat head and incan bulbs or you fit an aspheric lens into your bezel.
Mod'ing ease isn't the point. The point is that the OP asked for advice and the suggestion of using a SureFire KT1/KT2 Conversion Kit TurboHead is a valid one. MrGman incorrectly dissed that suggestion -- I quote 'fancy schmancy "turbo" heads that may or may not fit and adapt to your original host' -- when in fact that TurboHead is specifically designed as an upgrade path for the SureFire 6P if you want more throw.
If one wants to discuss the pros and cons of various suggestions, then at least it is advisable to get the facts correct before claiming that some product "may or may not fit" when in fact the manufacturer itself has specifically designed it as an upgrade path. Thus, I'm not sure why you want to "back up" factually incorrect statements. But that's your choice.
The factual downsides of a KT1/KT2 are:
- Extra cost for the TurboHead (about $100 for a new conversion kit, minus any money you might recoup by selling the included incandescent lamp)
- Extra size and weight
- Extra cost for the LED Turbo Tower (assembled ones on CPF Marketplace and on the B/S/T forum are typically over $100)
The upsides are:
- Brighter hot spot. I've measured a 1 meter hot spot lux of over 20,000 for an XP-G R4 tower driven by an SOB1227. This compares to about 8700 lux for my M30 driven at 1050mA by 3xAMC7135.
- Huge, bright spill
- Superior heat sinking
- Easy capability to upgrade to the latest LED technology by mod'ing an existing tower or installing a new tower (for example, I have SSC P4, Cree MC-E, and Cree XP-G towers)
- Easy capability to optimize for various battery configurations by using the appropriately built tower (for example, I've used SOB buck drivers, AMC7135 drivers, and KD1640 buck drivers for 1xLi-ion, 2xLi-ion, 3xLi-ion, 2x123A, 3x123A, and 4x123A)
Unless you go to a bigger reflector you are not going to get much more throw. The FM1794 D26 throws like crazy but the bulb life is very very short, they are extremely fragile and run time is very short. As well you cannot really get them anymore. I have messed with many different options and have come to the conclusion that for throw you need a turbohead. I think the led towers are going to get more popular now that the XP-G is starting to get used with them. But then sticking a turbohead on you loose EDC capability. FM also came out with a turbohead but I dont think it works well with the malkoff since it has an optic and not a reflector.
I am a malkoff junkie and love his products and have never had a problem. I think those damn things would run forever. But other people are using some higher powered stuff that he hasnt launched yet. Nailbender is using the sst-50 for example and that flat out throws, floods and melts bugs in the way. But until you get a bigger reflector the throw is not going to be like a spotlight! Hopefully Gene will launch the XP-G M60 at some point I would hold on for one of those if you want to stay in the stock body and head size.
Zach
Lumens factory D36 head and modules will fix this issue. the SMO-R2 dropin throws great.
Even their D26 modules seem to out-throw the M60.
I to found myself desiring more throw from my M60; especially when working nights at our local stadium and my partners Pelican 7060 puts my light to shame when trying illuminate some tailgaters tent across the parking lot. I've never seen any of surefire optics in action first hand, but from what I've heard that's what I'm looking for.
Has anyone ever consulted with Gene Malkoff himself on the matter. It's my understanding that the M60 is designed with a certain balance between throw and spill in mind. He built the M60f with for those who wanted even more spill. I imagine if he felt there was a high enough demand that perhaps he'd design an M60t.
The upsides are:
I will concede only that the KT1 kit will fit the 6P. Other than that its way up and over the top from what the OP asked for. He's looking for a drop in module (since the M60 is not beam pattern adjustable and depotting it in attempts to increase output is again over the top), you suggest 100 for the turbo head and then possibly another $100 for the parts to make it an appropriate LED turbo head. I don't regret using fancy schmancy, and its too soft for the ridiculousness of the cost, because, He could buy the latest Dereelight complete flashlight thrower for $99.00 and keep this flashlight fully functional.
the Dereelight R2 pill drop in and reflector to go in the 6P will give him more throw than he had for $40 or less and was something in line with what he asked for. So I will "diss" the turbo head option at its costs and weight/size increase for being way beyond what he asked for yet again, even if it does fit just fine.
:p
Seeing as how all of your other points are just your personal opinion, while the thing you concede is the only factual aspect of your argument, I'd say your defense just got blown.
What is one person's high price is another's reasonable one. We are already talking about a $60 6P light and a $55 drop-in module, for a total price of over $100. It's not as if the OP asked for some bargain basement solution for some cheap DX clone.
If you want to debate pricing, I've gotten a KT1 on the CPF B/S/T forum for $50. I can build a tower for $40 in parts. And I have. I cited the $100+ cost for an assembled tower to provide a worst case costing. Thus, my total pricing is $90 for the proposed solution, with a very strong price/performance ratio.
What is the tail current draw for the Dereelight drop-in? What's the lumens? What's the lumens stability vs time (i.e., heat buildup resistance)? What's the hot spot lux? I get ~0.5A for the XP-G using 2xLi-ion, getting perhaps about 250 lumens, 20,000 lux@1 meter, and long run time in return. I don't have an integrating sphere but measuring hot spot lux vs time for my KT1 THs has shown a lux drop of about 4% after about 25 min of continuous operation and holding that for the next 30 min.
The Deree pill/drop-in will give you what you are looking for at a reasonable price. I have both the M60 and the Deree with the OP reflector. Even with the OP, the Deree out throws the M60. That being said however, I still prefer the versatility of the M60. If throw is what you want for a 6P get the Deree. Flashcrazy at flashlightconnection.com has them.
Pelican 7060 put your m60 to SHAME!!!! I cannot believe that.
I have one of the recoil pelicans in my turnouts and it is minimag style to my malkoff. I think you were using dead batteries!
I think you just love to argue and bring up ridiculous points for the sake of arguing.
the most important "fact" of my argument was that he didn't ask for a turbo head kit. He asked for a drop in module if he couldn't modify or adapt the M60 for more throw. So I conceded that the turbo head will fit when I previously said it "may not" and to you that blows my entire "defense" out of the water as if it was even important. Its not. Its a side issue to something which points out to me again, you just love to argue for the sake of arguing. I pointed out a viable easily obtainable module he could drop in to his light and improve his throw. That is also a fact. Whether he likes it or not or its the best possible module is a matter of opinion, but pointing it out that's there to be had is a fact.
You brought up the numbers for the potential cost of the turbo kit, not me, now you are changing them. Regardless, I will concede up front before you even go there, that you got them at the price you stated and they could be had for that price by diligent searching on the marketplace forums over time. Its still not the same as buying a complete DBS V3 that will do all of that for $99.00. something he doesn't have to hunt and hope he can get it "used" on the marketplace and put it all together himself and then hope it works. As to the lumens and lux and all that. You are stating specifications and making references to something the OP did not state as requirements again to just drag more arguing points of yours into something. I never mentioned any specific values or argued that the example you were given was good bad or indifferent.
the DBS V3 will definitely outthrow the Malkoff M60 ( his reference unit) and has more than 20000 Lux at 1 Meter. I believe the V3 with the latest R2 pill will outthrow your turbohead kit as well. I have not measured its lumens ( no one asked for more lumens or even used it as a reference) or its run time on a set of batteries nor do I care. The DBS V3 can be had with various pills to run it on either 1 X 18650 or higher voltages which will reduced current draw and increase run time. The Dereelight modules also come in various voltage drive configurations so the OP can simply pick one of his choosing.
He could go buy the Tiablo A9 for less than your option and still have a complete flashlight with more throw. He could get it with the optional aspheric lens head and definitely have more throw and still be at or around $90. You could have mentioned that.
My 3 options are easily obtainable and viable options that don't require putting a turbo head on his 6P and trying to find one at a discount price that may not be available on the marketplace to make it cost effective, plus other parts. But hey, its just personal opinion. Or is it a fact that these options exist, and are more cost effective then your recommendation as you originally stated. And I nor any one else stated going the ultra cheap DX route. Again, you just love to argue.
So I am sure you will argue with this, but I am done. He as viable options.
And just for the record he is of course welcome to buy the KT1 or 2 turbo head kit and try to fit into it whatever he wants, its a free country, not saying he can't, just wondering why spend the money for those parts when he could have a complete second flashlight for less money and accomplish his stated goal.
somebody asks for help to fix a flat tire and you probably want to tell them how to build steel belted radials and where they could buy rubber. :thinking:
good luck morris.
lovecpf
maybe this will help?
you can see that the Lumens factory D26 module puts a tighter and more intense spot on the tree VS the M60. It does measure at less total output than the M60 in my sphere but not by much.
Dreelight and Lumens factory probably have the same reflector shape as do most of the aftermarket dropins. The difference is in the quality of the drivers and the set focus of the pill. orange peel VS smooth depends on how picky you are when white-wall hunting. The SMO will obviously gain more total output but again, not by a huge margin.
KT heads are in a league of their own, i can light up trees 3 blocks away with a MN16 on 18500's. Maybe i'll take some beamshots tonight...
lovecpf
Nice beamshots! :twothumbs
Please share the MN16 beamshots. You are giving me some good ideas. :D
