Firstly, I'd like to thank you for dedicating your time to this task.Hi Chaps,
I registered here to hopefully tap into your wealth of expertise. Please forgive any ignorance, as I'm purely a user of torches and have no knowledge of their electrickery.
I'm in a mountain rescue team, which means we are often out most of the night searching for people. I have a few related questions.
Sanyo cells are some of the best available. The default ones most of us use, are Sanyo Eneloops, which are 2000mAh low-self-discharge cells (can hold a charge for >1 year). The 2700mAh Sanyo cells are also very good, but will self-discharge relatively quickly.1. What are the best* cells available today in Sizes AAA, AA, D? *In that I mean balance of, highest mAH, self discharge, voltage drop off.
There are a lot of quality chargers available at batteryjunction.com, but Sanyo chargers that come with Eneloop batteries are quite good as well.2. My current charger is a cheap uniross ultrafast charger (Charging current = AA 1000mA; AAA 400maH). Will this fully charge the 2700maH cells I currently use + any you may recommend.
I would highly recommend the Fenix TK20, as seen here:4. The perfect torch for mountain rescue has the following criteria: Uses standard cells (AA pref for commonality with GPS), is as bright as possible, has a very long burn time, is weatherproof, and as cheap as possible. Just out of curiosity, what would you chaps recommend against my criteria so I can pass on the advice to team members looking to change their torches?
It can be purchased in high-visibility yellow from 4sevens.com
It'll put out 150 lumens on 2x NiMH AAs for 2 hours, or 40 lumens for 11 hours.
It's not CHEAP, but I doubt you could do much to destroy it.
