Thanks for the info. I didn't think of the bulb NOT staying in the socket.
Is there a mount for the M6? I may look at that option.
I've never seen a mount for the M6 before. Like Scott mentioned though...if there is a mount that existed for it you'd need and extra 8mm of clearance because the head is 15mm larger in diameter.
Do you know any machinists? It probably wouldn't be too difficult to make one for under $100, not including your time of course.
The Surefire M96, M97 and M98 series all take the KT4. The M500 dedicated forearm series also takes the KT4 which almost looks like a mounted M6. But you are right, I have not seen a mount for the M6(KT4+6 cell body).
Dave, one of my clients had a run of these made up to mount Boxers on his rifles. It was extremely well made and he was very happy and solid as a rock. It might give you some ideas.
