Th232
Been thinking about getting a mill and a lathe set up, and one of the main considerations is moving it all into place. Unfortunately, I don't have a garage to use (it's got something called a car in it, go figure... :roll: ), what'll most likely be the workshop is a room around the back of the house. First problem I hit is that there's a space restriction, anything going in must be able to fit through a gate 90 cm wide. To compound that, the path is on an incline, fortunately no steps, just a slope downwards. If it were flat, then a trolley or a series of pipes would probably be fine, but the incline poses a bit of a problem.
First bit I'm thinking of is a lathe. Was thinking of this:
https://www.machineryhouse.com.au/Products?stockCode=L141
Packing info (L x W x H): 137 x 73 x 73 cm
280 kg.
But then the bargain hunter in me is starting to cause trouble. There's also this one:
https://www.machineryhouse.com.au/Products?stockCode=L682D
Packing info (L x W x H): 168 X 75 X 108 cm
590 kg... :?
I only looked through it at first because I was going through the whole catalogue, first thought was "too much $$$", but then I looked closer (I have a tendency to read everything). What makes it tempting is all the extras that come as standard, I count a DRO, stand, coolant pump, quick change toolpost and 4 holders included in that.
If I kit out option 1 with all the stuff the second one has, it comes out to be $170 cheaper, but option 2 can take considerably larger jobs (900 mm vs 600 mm), and with a motor that's 2 hp instead of 1 hp. Knowing me, I have this vague feeling that I'll eventually be getting most of those accessories in the end, so I might as well get it over and done with. Suspect the DRO would be near the top of the list, blind boring Ti was a real pain last time I did it at a friend's place, I'm glad I have spare material. Expensive mistake, in both time and materials, would prefer not to repeat it.
On the other side, there's the bit in my head saying (probably correctly) that I can't see myself doing 3 foot jobs, and that the power difference will only mean that I spend a bit more time at the lathe. Frankly, I'd still go for the larger lathe though.
So the only thing that's really standing in my way (aside from needing to save up) is that I can't see any way of moving it down the path and not have it end up on top of someone or in the valley behind the house.
Any ideas on how to safely move nearly 600 kg down an incline (and probably up it in the future)? Or any thoughts about my lathe choices?
280 kg.
590 kg... :?
