regulator
- Joined
- Jul 22, 2006
- Messages
- 1,221
My impressions so far of the AAA Jetbeam-u are mixed. To me, it is an absolutely gorgeous light and made very well. It kinda reminds me of a micro-Surefire. I really like the memorize last setting and find it very useful.
I only wish the reflector was a little deeper (2mm or whatever needed) to concentrate the beam more. I do not think this would matter much since the light is so small anyways. The light produces almost all flood beam.
I think the converter/regulator is mediocre at best. With a NiMH or alkaline, it draws approximately 210 mA on low which is not very bright. The amount of output on medium seems low as well considering it is drawings 450mA. I have a ultra power Peak that draws about this much from an AAA battery and it puts out a lot more light for much longer. I also noticed that the Jetbeam-u gets warm running in medium and believe it is power "wasted" in the converter. For the amount of light output is should not be getting warm. Other small lights that I compared it to were all cool and putting out at least as much light (from ceiling bounce test).
Now what has sparked my curiosity is the advertised runtimes using a lithium ion battery. I believe that the regulator boost portion is bypassed with a lithium ion cell and may operate more efficiently as a result (only speculation since I do not have a lithium cell to test with yet). In low mode using the lithium ion cell, you get 25% brighter light for 75% longer runtime than in medium mode using a regular cell!! A lithium ion cell probably has a little more capacity than a NiMh cell but not that much more. Maybe the best way to run the Jetbeam is with a lithium ion cell?
Anyone with a Jet-u tested this theory??
