Hi, wondering if it is normal and ok if my Amilite T5 get's quite hot using AW's 3.7 RCR's?
If I am not holding it after about 12 minutes you can pick it up but barely hold it if you squeeze it..then it cools from my hand....any ideas on how this might effect the led life and if this is a problem?
Amilite says that RCR 3.6/3.7 can be used.
By the way if anyone has any questions about the T5 let me know as I'll be happy to answer them....thing is bright!! just wish I knew the actual tested lumens on it as I have no tester.
Thank all!
Thank all!
