warlord
I bought a WF-602D1 which I got instead of the RC-C3. I figured they're the same with one just having a better HAIII finish. Hard to say since I don't own both.
the good:
the bad:
I took out the pill and looked a the led, driver, etc. When I put it back together the LED was centered :thinking: What an easy fix, I didn't even have to take out my soldering iron!
Anodizing mismatch (can't do anything about this )
There's also the issue of the UF logo not being filled. It's laser etched and supposed to be filled white with ???. Anyway the logo was there but only visible at extreme angles. To corect this I just too a Sharpie and filled the whole area. Then I wiped it with a napkin followed by isopropyl soaked cotton swabs. The results:
Don't ask me what the white stuff is because I did the exact same thing to the CREE logo which was filled white and the results turned out fine:
Now, the twist action was fine without a cell but once I put one in I had to: first force the two halve together to get the threads to even engage; then tighten down the top which was noticably harder to turn due to the spring pressure...
So I fished the spring out with a ball point pen and shortened the travel by forcing it back through itself, if you understand what I mean.oo: The resulting travel:
Maybe 2mm now. So the flashlight is easier to put together and the action is equally smooth with or without a battery.:twothumbs:
So overall I'd say this is a good, not great flashlight. I don't think I should have to fix so many issues before I get to enjoy my new toy...I mean tool.:naughty: Anyway after the fixes I'm happy with the flashlight and I'll be testing it out as my ECD. My first real EDC that isn't attached to my keyring.
If anyone has had any issues with this flashlight or the similar RC-C3 please post up!
Thanks for looking!
the good:
- Bright light with good color
- small size
- handy clip -not removable (at least for me)
the bad:
- Off-centered LED
- Anodizing mis-match
- Ultrafire logo not filled white (but CREE was)
- Spring too long -making a noticable difference in twist action with and without a battery.
Thanks for looking!
