Northern Lights
First many thanks,
BVH for starting the L30 thread
Isak Hawk for pointing out the L35 arrival to me in my other thread
Matt and Jeff for helping with product, I will get those other components per my emails!
mtbkndad, thanks for the conversations, techy stuff, here it is, done...
I am building this thread backwards, take a look at these up grades for the N30 HID spot light:
IMPROVE THE N30 HID add a 225 Lumen R2 LED area light and GLOWING LED locators
The R2 module burned out the driver so I switched it to a direct drive on a parallel resistors totalling 10 ohms, 10 amps and the math is there for the always glowing GID locator 3x 5 mm LEDs.
I upgraded this new pack, the resistor is 15 watts and 11 ohms and is now on the under belly inside a piece of copper tube as a heat sync. It gets hot. Originally it was in the handle tube. The R2 is good for 225-250 lumens. The 5mm LEDs I have on 600K ohms, those are 3x 5mm LEDs running Vf=3.2, @ 0.20 mA. on 600K ohms using the LED_Pro program which is found linked in the above linked thread on improvements, it should be bout 0.01 mA or 0.00001 Amps used to make that glow. Those glow and locate LEDs are also on a pust button switch so can be turned off. That swith is in the front panel below the small R2 area light.
Now what did I do:
My battery pack went bad. OEM is a pack of 11 in series 3.6 mAh NiMh cells for 13.2 Volts at 3.6mAh. You see there is room for 12 cells. And the charger has some leeway in it and will charge 12 cells. I had a 12 cell 5000 mAh pack made. The original pack has about 47 watts of power, this pack has 72 watts of power. About one and half times more run time.
I also took that bunch of wires and the harness and straigthen that mess out. The original pack has two leads going to the pack terminals for the light and jumpers to the battery. The "fuel guage" had a yellow wire going to the negative terminal of the batteries and in the glob of glue was a small resistor of 11 ohms the size of a # 6 lead shot. I took the resistor and put it into the board where the yellow wire came out, Attached the yellow wire to it and epoxied that fragile resistor down. I shortened the yellow wire and grounded it to the large connection point of ground on the power jack on the board. Now I had a lean harness to pack back in.
But do this if you make up a pack. Make sure the wires on the pack come out on the same side as the board and unit terminals or you will, like me must cross the wires on top of the pack and you need to do that so you do not crimp them in assembly or create a condition that later could cause a short by vibration and pressure wear.
You can get an assortment of sub C cells and make a pack, maybe they make packs too, from Battery Juncion, Matt and Jeff.
If you are inclined to have a pack built LuxLuthor, my bud, is very good at that also. This link. Custom Battery Packs - Made To Order . He uses B.J. cells in his packs.
To take the light body apart you just yank the feet off the black straps and they open up. Screws take the head off. To disassemble the battery pack carefully lift the face lable off the pack and two scews are locatd underneath. I found the screws had split the anchor columns inside the pack and that needed repair.
Warning! This has a ballast and high voltage. You better have some skill and training about these things or it can hurt you, bad!
Now what did I do:
