ultrarunner2015
- Joined
- Nov 23, 2014
- Messages
- 57
I have an aging Black & Decker Smart Battery Charger. I don't know the exact model #, but the front panel looks like this:
https://drive.google.com/file/d/1rXjgIQqwtuBiFAlZAir6nLjUJ9M14TcD/view?usp=sharing
Today when I needed to use the charger, it required repair. The AC power cord shorted on the PCB, causing the GFCI breaker to which it was connected to trip. Surprisingly, despite the fact that the ground (shield wire) of the power cable momentarily contacted the internal fuse - on the fused side - its fuse did not blow.
After the repair, I was able to charge my car's AGM battery.
The battery is Bosch Platinum series AGM size 35.
It has the following specs:
CCA @ 0F: 650
CA @ 32F: 780
RC Mins @ 2.5A: 110
Ah (C20): 53
Considering the Ah of 53, I charged at the 10A rate, not the max of 25 available on this charger.
I don't really trust this charger anymore, considering one major flaw: The power cord has no strain relief. It goes in through a hole in the rear and can be pushed in (but not pulled out due to a ferrite on the cord). But the cord is stored in a rear compartment. After about 10 years of use, the cord was moved enough to cause the problem inside on the PCB.
Can anyone recommend a good charger to replace this one?
Oh, and btw, let me mention that I don't drive the car (a 2004 Subaru Forester XT with about 55,000 miles) all that much, so it sits in the driveway sometimes for weeks without being driven. I normally put the charger on about every 2 weeks, but during the heavy snow last month, I failed to charge the battery for at least 6 weeks, and only drove the car a few miles.
I have checked the alternator, and it appears to be working fine.
I have also been thinking that perhaps I might want to purchase (in addition to the regular charger) a solar trickle charger that I could leave connected to the battery and place on the hood or roof to allow it to charge every day.
Thanks
Ultrarunner
CCA @ 0F: 650
CA @ 32F: 780
RC Mins @ 2.5A: 110
Ah (C20): 53
Thanks
Ultrarunner
