Nailbender kindly agreed to sell me a "linger special" basically two Cree XPGs mounted on one PCB (in Parallel)
He advised I purchase the 8x7135 driver to power these fully (1400ma to each)
However I would like at least Hi/Low or Hi/medium/low NO STROBE or SOS.
I did some research myself and ended up with these Candidates:
http://kaidomain.com/ProductDetails.aspx?ProductId=5595
Hightlights:
- Designed to run a parallel wired MC-E LED
- Modes: High/Middle/Low
- Buck current regulated circuit
- Output Voltage: LED voltage
- Current output: 2.8A
- Output level: 100%/30%/10%
- With a mode memory
- Dimension: 19mm
or
http://kaidomain.com/ProductDetails.aspx?ProductId=9534
Output Voltage:
2.8A(High)~ 1.38A(Middle)~0.25A(Low) --at any voltage level from 5.5V to 13.2V---Current regulated
Caution: No more than 3 D-size Li-ion Batteries (4.0V~12.0V) for protection this LED board
I'm planning on running this off of 2x18650.
Would either one of those be better then the other? or is there something else I should be using?
Hightlights:
- Dimension: 19mm
or
Output Voltage:
