need help identifying a flashlight.
tpolley
kansas
I need help identifying a flashlight. I saw it in a tv show. It's anodized aluminum. Its about as long as a 4, 5, or 6 cell mag. With the exception of some gripping surface texture its the same diameter along the whole length including the bezel. The distinguishing feature is it has a led array/work light on the side. The show took place in England and the guy using it was from Ireland. If that helps.
Ghost hunters international. Chilling castle episode. The gentleman using the light was Barry Fitzgerald.
not sure if I was clear in the original post but the light had the led array or work light in addition to the main spot light or focused light
Thanks!
It sounds like a cheap generic "multi-use" light available at target. I don't think ghost hunters international spends much on gear...
