Need Help Wiring a Battery Pack
holdthat1
It so happens that I have alot of AA 2600 mah batteries laying around (twelve to be exact) which would help me out greatly with my next mod. I plan on using a 3up xp-g from led supply and using a kennan driver @ 1 amp. I know since the driver is a buck regulator , the input voltage needs to be 1-3 volts higher than the ouput. Heres the problem Im having, Im a bit confused when It comes to wiring a battery pack. Will the configuration above provide 14 volts and 5.2 amps?
Richard
