roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
(Manufacturer Supplied)
Specifications
- CREE XM-L U3 bin LED with 50 000 hour life span.
- Maximum output: 715 lumen
- High efficient constant current circuit and output-luminance
- Micro controller drive circuit
- Tactical High Mode, and On side switch Infinitely variable brightness system
- Hidden Strobe and SOS, Quickly click 2 times side switch ---> Strobe , and quickly click 2 times again ---> SOS
- Working voltage: 2.7V--8.5VDC
- Battery Types Supported: 1 x 18650 or 2 X CR123A
- Runtime: High output at 2.6A: 715lumen max for 95minutes. Low output at 0.01A: 1 lumen max for 128 hours
- Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
- Color: Black
- Ergonomic grip with anti-roll design
- Tactical forward tail cap switch
- Bezel: stainless steel
- High performance aluminum smooth reflector with concentrated beam shot
- Waterproof: IPX-8 Standard
- Lens: Toughened ultra-clear coated and anti-abrasion glass
- Dimensions: Length 173mm, Head Diameter 48mm ,body 25.4mm
- Weight: 182g excluding battery
- Accessories: Lanyard, spare o-ring
Features
- Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search& Rescue and Outdoorsman
- Tactical-on side switch Infinite brightness accessible
- Stainless steel retaining ring on the bezel protects the head from drops and impacts.
- CREE XM-L LED
- Max output of up to 715 lumens with an effective range of 400 meters
- New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability
- Newly designed high efficiency broad voltage drive circuit
- IPX-8 standard waterproof
Specifications
- Color: Black
Features
- CREE XM-L LED
