BabyDoc
Re: New Fenix TK10/T11 (replacing T1)
I don't own a T1. So I don't know if Fenix warns you about overheating issues in Turbo mode with that light. This warning appears with my L2D and several other Fenix models having the Q5 emitter. It could be Fenix is protecting themselves more than the people they warn. There is a warranty with these lights and I suppose they don't want trouble should people run them full throttle for too long.
I really don't know much about heat sinking in anything but the p120 which is specifically designed with heat sinks and thermal protection. However, that is a $170 light and shouldn't be compared with a T1 or T10. Furthermore, it produces fewer lumens and may not really need all this protection unless the light is exposed to abuse (leaving it on in your pocket or backpack). It just seems that some theoretical issues with overheating with lower outputs for which Fenix gives warning, may become more real the more lumens and the more heat that is generated. Of course more lumens doesn't necessarily mean more heat, provided the lumens are generated more efficiently. Certainly, to some extent, that is the case with the Q5's. More light with better runtimes, means more lumens with less energy expenditure per minute. Hopefully, the beefier T10 can absorb the heat better. It will be interesting to see if their warning is still given, though if it were me, I would probably just ignore the warning and use the light.
When you say "the other Fenix lights" are not well heat-sinked,
are you including the predecessor to the TK10, in other words the T1?
Although I haven't seen the T1 in person, from the pictures it looks like
it would be more than adequate to cope with the output on high for an
extended period of time.
The walls are extremely thick anodised aluminium and provided there is
an adequate thermal path to conduct the heat from the led to these walls,
there should be no problem with a light of this size.
In the much smaller Fenix lights, its common sense not to keep them
on high for too long. When you feel the light becoming very hot, its time
to dial down the output.
There is just not sufficient surface-area of metal in the smaller lights,
regardless of the actual heat-sink used, to dissipate the heat effectively
away from the led.
