New fixed light prototype
Barbarin
Pamplona- NA- Spain
I have developed a new lamp, displaying 336 Leds, PLCC type, 20 mA each, 24 V input. The light angle is 120º and 4000 ºK. Near 2000 lm.
LEDs are protected by a clear epoxi layer, optical grade, so the whole thing is IP67.
It is 2500 mm long, arround 750 gr and it was made for testing, but the results are quite promising. Its consuming 24 Watts, but the real light being put in front of your eyes is better than the one you can get from a 40 Watt fluorescent, as there is no need for inefficient reflectors or housings.
Comments welcome, as always.
I have to ask the obvious question in why use 336 20mA LEDs instead of far fewer 100mA SMDs? Or 1/2-1watt generic LEDs?
Linear light rods like this are all over the place - just wondering what you're doing differently.
I have a 2-foot fluorescent tube replacement I received for testing which uses 4.8 mm low dome LEDs ( 165 IIRC ). As for why, basically you avoid the need for aluminum extrusions or any other type of heat sinking. The one I have has the LEDs mounted on standard FR-4. The rest of it is plastic. From a manufacturing standpoint it costs less mounting a bunch of emitters on FR4 with standard flow solder techniques than epoxying and hand connecting maybe ten or so power LEDs. The driver requirements are less complex also. In fact, you could probably use a simple capacitor fed full-wave bridge, then filter the output to prevent flicker. For power LEDs you need to drop the AC line voltage to a few tens of volts, generally with some kind of switching power supply. Incidentally, lumen maintenance is excellent. After about 3000 hours output hasn't dropped measureably.
Good questions.
I do preffer many small, not that bright diodes over a few high power ones. Light distribution is better, you have less noticeable shadows, and heat dissipation is always better as you "spread" better the heat.
I'm doing basically some experiments, getting information about declared and real efficieny, and about some other characteristics such as weather and waterproofness, durabiliy of adhesives.... Main difference on this profile is its lenght and its structural capabilities. I want to fit the leds with different optics to get narrower beams.
Confused. Even if you are using 20mA emitters, thermal coefficients do apply and I don't see why this matters. You still have to remove the same 24-watts of heat and I don't see how using a horde of smaller emitters changes the equation. Energy in = energy out. Although, this does explain why the cheaper versions of these lights have poor lifespans.
Again, confused. Right now SMDs in the ~100mA to one watt class seem to be ruling linear lighting, correct? I see them everywhere from lights like these to grocery store freezers. Again, where does 20mA lighting come in, what problem does it solve over ~100mA SMD, and why would using 5-10x as many of them be cheaper?
In theory, but can you run any type of LED this way, correct? Again, 24-watts of 20mA emitters consumes the same power as 24-watts of Bridgelux or Crees. The voltage drop is determined by the series value, and obviously the less you have to muck with native voltage the less penalty there is along with making your driver cheaper. Still, we're talking about lumen values in the thousands at 24-volts and not 180 lumen retrofit bulbs. Plus, isn't a regulated driver mandatory for safety, or are we talking strands of xmas lights here? :poke:
Ok, now we're getting somewhere. I ran into this problem at the other extreme working with Bridgelux. Basically, once you start moving above 3-watts per die thermal dissipation start getting bottlenecked by anything less than 1/8 thick aluminum. Heat simply can't move away fast enough. At 10watts, you need 3/8 thick metal. At 20watt, I'm looking at thick copper plate combined with aluminum to move the heat. So yeah, using a lot of smaller emitters makes this easier. Still, ~100mA SMDs strips don't seem to be having a problem with this.
Spreading the light though has a substantial benefit. I'm trying to figure out how to do this efficienctly with larger emitters.
Neat discussion. Thanks to Barbarin for letting us banter around the 'why do it that way' chatter using his new product as a discussion point. jtr1962 always gets a kudos.
Yes, you're quite correct about that. The thing is given the surface area of a T8 fluorescent tube replacement, you can keep temperatures reasonable with roughly 3-4 watts of heat per linear foot ( this assumes the tube is in open air of course-an enclosed fixture would require lowering the wattage ). The two-foot flouro tube retrofit I have draws about 9 watts from the AC mains and is speced for 700 lumens ( and yes, it does seem to meet this spec although I didn't lumens test it ). So figure about 2 watts of those 9 going in come out as light, the remaining 7 as heat. The outer part of the tube is roughly body temperature. Inside is a little warmer, perhaps 40°C. Given the junction to ambient impedance of typical small LEDs ( on the order of 200 to 300 °C/W ), I'd expect the junction temperatures to be about 60°-65°C, which is plenty low enough for long life.
Correct, using 100 mA SMDs over 20 mA gives you about 1/5 the number of parts, so it would be cheaper. 100 mA LEDs represent a good intermediate point between the more difficult assembly using power LEDs, and the much greater number of LEDs using 20 mA types. That being said, as Barbarin mentioned in some instances you might still want to go with the 20 mA type for better light distribution and heat spreading. I've been modding nightlights with 20 mA SMD LEDs. I don't really have any 100 mA types anyhow, and I find the 20 mA ones give more even light distribution and less complex drive requirements. It turns out in order to reach the desired output you often need to run enough emitters so that the total Vf is an appreciable fraction of the line voltage. In some cases you might even get by with a simple filtered full-wave bridge. Worst case a capacitor-fed ( i.e. current-limited ) full-wave bridge is all you need.
Yes, you can use a capacitor-fed full-wave bridge to drive even power LEDs. The kicker is that the current-limiting cap has to be on the order of 10 uF or so, if not larger, and rated at 250 V or better ( for 120 VAC line use ). For 240 VAC the requirements are even more onerous. Such caps cost quite a bit more that the 0.47 uF or 1 uF ones needed to drive 20 mA LEDs. Not an issue for a one-off DIY project, but a problem if you're making hundreds. Given the cost and size of the needed cap, in most cases you're better off going with regulated switching supplies for driving power LEDs off line voltage. And no, a regulated driver isn't mandatory for safety, but honestly I wouldn't make a power LED setup for anyone, except maybe myself, without one. You can fuse and protect a capacitor-fed full-wave bridge, of course, but this type of circuit really mostly makes sense for driving 20 mA, and perhaps 100 mA LEDs. Just because it can be made to work with power LEDs doesn't mean it's the most optimal solution.
And if you ever do it might well be patentable. I'm not kidding. One of the big problems with power LEDs is the fact that they're an obnoxiously bright point source. This is one reason alternate solutions ( 20 mA and 100 mA ) are still being used ). Even in cases where the heatsinking requirements aren't onerous power LEDs might be a nonstarter on account of not easily being diffused. Yes, you can go the indirect lighting route, aiming the light bars at the ceiling, but you squander a large portion of your efficiency in the process. Some solution of diffusion so you can use the light directly would be quite welcome. I have seen light guides where a light source is put on the end of a tube, and then the tube lights relatively uniformly, but IIRC the efficiency of those is horrible. I was actually trying a homemade version of this a few years ago when I was trying to light HO scale coaches because all I had at the time were narrow-beam 5 mm LEDs. Of course, that project got shelved once I found the wide-angle Osram SMD LEDs on eBay.
hank you friends, this has become a very interesting post. Here is some aditional information about my own tests and obsrevations.
Size and output of the LED: IMO the use of a few lighting points is an heritage of the past. Light emitters had a limited lifetime, you needed to replace them , and the efiiciency of low wattage bulbs or fluorescents, even vapour lamps, was lower than on high power ones. Our conventional idea of lighting is "Hey, let's put a bulb hanging from the ceiling"
What is the inconveniene of single or few high power emitters? First of all you are going to create a lot of shadows, and in order to compensate that you are going to need to use more emitters. For example, we all have experienced this trying to read a book with the emitter/lamp at our back. Second, as the emitter is very bright, if you ever look at it or its reflector, or even the area which is being lighted closed accidentaly you will get outshined for a while, so all the benefits of the incredible adaptability of our visual system will be lost and wasted.
So, it is more effective to have 1000 x 1 lm light points, than just 1 x 1000 lm. In fact, if you have a single point you need more than 4000 lm to light up a big room, and to get the reflexion on the walls to fight the shadows.
Using low power LEDs have other benefits when it comes to manufacturing. You can use flexible PCB, which is cheaper than MCPCB`s, and if you are using them, you can make lamps with very complex forms.
Javier
:popcorn: Would you care to post pictures of the fixture itself? :popcorn:
As you can see the prototype was made for 12 V, but now I'm studiying a 24 V option to reduce the current.
Do you like it?
