the dome of the K2 TFFC is the same as the high dome of the Lux I or III, but the LED die is recessed a bit lower inside the reflector cup. Another difference is that the body is square and thus you have to insure that the light you are swapping emitters in can accomodate the new shape. Also as a final note, the dual gull wing (4 lead wires, 2 on each side of the emitter) have a shorter length than the gull wings on the Lux I, III, or V. So basically you have to fiddle around with a method to fit the K2s leads onto the same contact board that used to be used for an older 2 lead luxeon. other than that it should conform with most existing luxeon optics (you may need to see if your light can accommodate an McR xxJ reflector) since the die is sitting lower in the reflector. Other than that, the new K2, as other members have said has awesome Color rendition and is much brighter than the older LXK2-PW14-U000 or V000.
