Thanks thedoc007, would you have any comments on how you like the tm26 versus the s6330?
I don't own the S6330, I was basing my response on the specs, and what I know about the S6330. Although the candela rating is hard to find for the S6330, we can figure it out fairly accurately. The Zebralight is basically 3 SC600s wrapped together - the reflectors are totally separate, and exactly the same size as the SC600 reflector, so adding the candela rating of three SC600s give us a rating of around 15-16k candela. The TM26, on the other hand, is rated for 43k lux@1m, nearly triple the intensity by the numbers. In real world use, of course, it will not throw nearly 3 times as well, but given that it has 1100 more lumens to work with AND better focus, it WILL be significantly better at medium to long range. The reason I like the Nitecore so much is because it is so versatile...massive flood, but also capable as a thrower for PRACTICAL distances, whereas the S6330 is a dedicated flooder.
As for the size comparison, I didn't find any direct comparison between the TM26 and S6330 in a quick search. I did find
this thread, though, where Tatopus kindly posted pics comparing the TM15 to the Zebralight. The TM26 is a little smaller than the TM15 (smaller reflectors, shorter head), but it does give you a pretty good idea. If you want compact, you already have the right light...the Zebralight really is amazingly small.
I hope someone else can help with a direct comparison...
