New QC procedures
Status
Not open for further replies.
Gransee
Mesa, AZ. USA
You will start to see new QC (Quality Control) procedures on our LS next week. As this progresses, each LS flashlight will be sealed with a QC sticker signed by one of our QC people.
Before gaining that sticker, the flashlight must be checked against a list of items like housing, LED, switch, etc.
I will post here this weekend what our QC list is so you will have a better idea of what to expect from Arc product.
This could take several months to trickle out to all the dealers as old stock is sold and replaced with new stock.
Peter Gransee
OK, here is the first draft:
Arc-LS Checklist
1. Check to make sure all parts are present:
a. TSP-123 pack (for models that include pack)
b. split ring
c. enclosed in plastic bag, sealed with QC sticker
d. instructions
e. battery (if model includes battery)
f. Lens protector (for models that include protector)
g. O-ring on power pack
h. Tail switch
i. Electronics
j. Optics
k. Laser engraving
2. Look at the cosmetics of the light
a. Anodize tint match between all pieces (reject gross differences, pass slight differences)
b. Anodize blemishes (reject gross blemishes, voids, rack marks, scratches etc. Pass slight discolorations, low observable scratches). Don’t miss the area around the lens.
c. Interior is visibly chemkoted, (reject gross blemishes or voids)
d. Check knurl of head and power pack for milling errors (ghost knurl, gouges, etc)
3. Tail Switch
a. Light stays on when switch is clicked
b. Light does not flicker when switch is left on
c. Tail switch is completely seated into threads of pack, boot is completely tucked in on all sides.
4. Miscellaneous
a. Tail pack threads smoothly onto head all the way
b. Thread and o-ring is oiled
c. O-ring does not squeak
5. Focus on the optics
a. Optics not loose or rattling
b. Lens is completely flush with bezel of flashlight
c. Lens protector installed and free of large bubbles, properly centered and adhered
d. Lens free of metal flakes, hair, scratches or dust (pass light dust)
e. Lens free of “fracture sparkle” around LED
6. Beam of LED
a. Beam centered (use target)
b. Tint within range (eyeball)
c. Brightness within range (eyeball)
d. Does not flicker
e. No gross blotches in beam (pass slight variations)
7. PCB details
a. Back of PCB is not heavily scratched by centering tool
b. copper ring present
c. nut tightened all the way down
d. gold button present
e. Nut secured by silver epoxy or red loctite
Ah, so that's why my order's on hold so long.
Just joking.
For part 1, I can't comment on the completeness (although it certainly looks thorough!) because I'm just about to get my first Arc. If it's meant to be an ordered list though, wouldn't 1c (sealed in bag) go before or after all the light-check things such as laser engraving and lens protector?
Beyond that, were you thinking of distributing the checks to respective assembly stations so that it doesn't add overhead by #2-7 being done at the end of the line after the light has presumably already been assembled?
Wow, quite a checklist. Sounds like the customer will benefit greatly and you will now know who boo-booed and passed an out of spec item.
Good thinking.
Status
