Gadgetman7
I suspect the G&A specs are wrong. It's likely run on 10440....
It's in the video link above posted by Casun. Go watch it. Interesting. There's also a P3X Fury replacement that takes 3 CR123 or 2 AA and its designated the PMX. Design looks similar to P3X though.Brass, wow. Mind linking any of these sources you guys are reading titan plus info from, or seeing other pics like the ones we have here of the Al titan?
The Titan Plus will need to be run on an Eneloop to hit full output. The weapon light will hit its mark with lithium or Alkaline AAAs. It seems that the Eneloops don't hold up as well under recoil (at least for now)
The run times won't be directly comparable between the Titan-A and Titan Plus. In addition to the difference in high output, they use different electronics and will have different types of discharge curves.
The Titan-A should be out pretty quick.
Step-down regulation.Both models do 2 hours on 15 lumen which makes sense, on high however things get weird as the Titan (product code Titan-A) does 125 lumen for 30 minutes and the Titan Plus (product code Titan-B) does 300 lumen for 1 hour so more than twice the output with twice the runtime?!?!?
Exactly. The 125 lumen will have a fairly flat discharge curve and drop fast at the end. The 300 lumen version will step down earlier.
Someone asked for a photo. Here's a shot of the two new Titans alongside one of my T1A Titans. (From here)
Nice! So umm what is the price on the Titan Plus?
$99.99 last I saw.
Ok, more confusing specs from Surefire in the 2015 catalogue:
http://www.surefire.com/media/wysiwyg/main_site_pdfs/2015_Full_Line_Catalog_ps.pdf
