mellowhead
I just got my brand new H600w in the mail the other day. I also ordered some NCR18650B's (unprotected) to go in it from DX. Now, I haven't done any discharge tests to check if they are actual genuine Panasonic 3400's, but I measured the length and they are precisely 65mm long. Tried it in the light and the tailcap screws on nice and tight, no problems whatsoever - light works great. Looking at the tailcap on the H600 though, it's quite obvious that if the tailcap is not completely screwed on, it will not make electrical contact. This is because the threads are not what carry the electrical current; it's the copper ring around the inside base of the tailcap that makes contact with the non-anodized surface at the end of the battery tube. Seems pretty straight forward to me - if the tailcap can't make electrical contact (not fully tightened), the light won't turn on.
Jahna - as Bribo mentioned above, you won't need the protection circuit for the discharge side, as the low cutoff built into the light is higher than the NCR18650B's are rated to discharge to anyways.
Lightcycle1: Virtually all manufacturers who add the protection circuits add different protection circuits. Different protection circuits have different components, varying electrical specifications, and, yes, different dimensions as well. The circuits will ALWAYS add some length to the completed cell, but that can be anywhere from 2(?) to 5mm or so. Obviously, smaller is better for fitment & compatibility but tradeoffs come with a small size. Smaller can mean less current capability, and often means more expensive to produce.
