Hi all,
i'm after some help regarding spotights. what i am wanting to do is build/buy a spotlight that is being used for night shooting of pesty animals. the light will be handheld, but be powered by the vehicles 12v battery. so power consumption isnt too much of an issue! it wants to be fairly well balanced in terms of weight, and perferably not too large in diameter so its easy to manuvoure while getting in and out through windows etc.
now being quite a n00b with lighting, i am pretty unsure of what it is i need or really want.
is LED, HID, or halogen the way to go?
so heres a few requirements. need to be a very focused beam, not a flood style. i want to see very clearly at ranges of 150+m, and needs to as white as possible. i dont mind having to build a unit, or buy one premade. i would prefer to not spend alot of money if it could be helped lol.
my only hesitiation is being that i live in new zealand and i'm worried about the costs of shipping..?
here's the checklist:
___?_I would like to purchase the light from a brick and mortar store. I am located in ______________.
_?___I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $150.
3) Format:
____I want a portable spotlight - but to be powered by automotive battery
4) Flashlight-specific format/size:
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
_?___LED
__?__Incandescent
__?__HID
6) Manufacturer:
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this option can provide more options to the consumer to meet specific needs.
7) What battery type do you want to use?
N/A
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I walk ridiculous amounts of lumens (800+ lumens). AS MUCH AS POSSIBLE
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
N/A
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
12) Switch Type and location (choose all that apply):
____I don't care.
____I don’t know.
____A simple on-off is fine for me.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
____I don’t care. SO LONG AS IT DOESNT MELT WITH POSSIBLE HEAT
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
NONE THAT I KNOW OF?
Thanks in advance for any and all of your help!
____Less than $150.
3) Format:
_?___LED
__?__Incandescent
__?__HID
6) Manufacturer:
N/A
N/A
____I don't care.
____I don’t know.
____I don’t care.
____I don’t know.
