First of all, I am sorry if I posted this in the wrong thread. Second, I apologies if my grammar is atrocious.
I was wondering how much cooling is needed for a mce/p7? Also what are some of the advantages of the p7 vs. mce. If I did a maglite p7 or mce mod and shortened the barrel, so just the switch is left and a little extra so I could put the tailcap on, then cut fins into the reflector, would that have enough cooling? I thought they would because Elektro Lumens has 3 mce maglites, about 30watts of heat, and they can stay cool. I was thinking of using this light as a bikelight aswell as just a normal flashlight with the battery in my pocket. What about this light though https://www.magnalight.com/pc-45232...t-spreader-light--800-lumens--waterproof.aspx and this one https://www.magnalight.com/pc-2046-...t--800-lumens--2-inch-square--stud-mount.aspx ? Those look realy nice because they are premade and not too expensive and they sound like they have a really good driver, tell me if I understand this correctly, if you put higher voltage into that it will draw less amperage? Another question how easy is it to drive a ssc p7, and is this a good driver http://www.kaidomain.com/ProductDetails.aspx?ProductId=1866
