TorchBoy
That result of 78%, SilverFox, would you immediately retire that cell, or is your limit 80% of initial tested?
It's called flashaholicism....it's very difficult to treat.I have this growing itch to know more about my batteries, even when they are just sitting there doing nothing, and to purchase more flashlights than I will ever need. Do you have any pharmaceutical recommendations for this affliction? :green:
I'd like to check on how fast the batteries self-discharge in a month. Any suggestions on how I can accomplish this with the C9000?
If I understand it right, the "Discharge" mode runs the batteries down to about 1.1v, then stops (I guess this is a safety feature?). Whereas, the "Cycle" mode runs the batteries down to 0.9v, so the two results are not comparable.
The Discharge mode on the MH-C9000 runs the batteries down to 0.9V, as does the discharge part of the other modes (where applicable - obviously the Charge mode doesn't have a discharge part).If I understand it right, the "Discharge" mode runs the batteries down to about 1.1v, then stops (I guess this is a safety feature?). Whereas, the "Cycle" mode runs the batteries down to 0.9v, so the two results are not comparable.
Ummm....Isn't there a post on here somewhere where you said that you usually have 10 chargers on the go at any one time? Might need a stronger cup of coffee:devil: As far as a pharmaceutical recommendation goes... I usually find that a good strong cup of coffee goes a long way to clearing my head... :devil:
The results were less than 25% of the purported 1200 mAH battery capacity.
I contacted the vendor and asked for instructions for getting a refund.
I suspect 0.5 mA is a typo and it was in fact 500 mA. Discharging 300 mAh at 0.5 mA would take about 600 hours.1dash1 - not that I think those cells are 1200mAh but a .5mAh discharge rate isn't appropriate for a claimed 1200mAh AAA cell. A Discharge rate of .2C, or .24mA would have been the correct choice by which to rate the cells by as that is the IEC standard which is used by battery mfrs.
