bondr006
This is a preview of the soon to be released Infinitely Variable Infilux IFE1 XPG-R5 from NiteCore. The sample was kindly provided to me by the guys at LightJunction.com.
Well, I have had the light since yesterday and I can't wait till they ship. I must have one. I have had a few NiteCore lights and this one is just a beauty. Nice fit and finish, beautiful beam, outstanding UI, and just feels nice in the hand. From what I understand, there are two more models to be released also. A 2xCR123 model, and a 2xAA model. The action on this thing is just so smooth. It is one continuous ramp from a very nice low of 0.1 lumen, all the way up to a whopping 285 lumen. I really like the UI on this. The ring just works very well. At the bottom of the ring it sits in an indent/off postion. You turn the ring to the right to start ramping up, or turn it to the left for a strobe. You can leave the ring at any position for it to come back on in the level you wish. The light is activated by a forward clicky. The XPG-R5 puts out a very nice beam. This is the first XPG-R5 I have seen with a smooth reflector. Still a nice smooth beam with a more intense hot spot.
link removed
I am glad we are getting close to the release of these lights. I have been wanting one ever since I first heard about them.
Below is what there is so far of the manufacturer's description, and then all the pictures I took. I will try to answer questions as best as I can.
Now on to the pictures....Enjoy!
Q Mini 123, Milky ME1B, JB RRT-0, NiteCore D10, NiteCore IFE1
1 Meter at highest output
1 Meter at lowest output
Control shot for some comparison shots. 25ft to door. All lights at max output.
Infilux IFE1 XPG-R5
EagleTac P20C2 Mll XPG-R5
Q Mini 123 XPG-R5
JETBeam RRT-0 XPE-R2
link removed
NiteCore said:A smart ring light with unlimited modes! You can get infinite output ranging from as low as 0.1 lumen to 285 lumen by simply rotating the smart ring control!
IFE1/IFD2 adopts a new generation of Smart Ring design, a rotary selector with infinitely variable brightness function (similar to Surefire Titan), also comes with strobe mode. The light head is compatible with Surefire E1 series (using one single CR123 battery), equipped with CREE XP-G R5 LED, Max output reaches 285 Lumens and Min output as low as 0.1 Lumen.
Features:
- Infilux line is NC's top product line.
- Compatible with the Surefire E Series tube.
- Not only rotary switch, but also tail switch, could be tactical application.
- Rotary selector with infinitely variable brightness function
- Using the newest CREE XP-G R5 LED.
- With strobe mode.
- IFE1 uses one CR123A battery.
- The diameter of the head: 23mm
- The biggest diameter of the body: 23mm
- The Total length: 102.3mm
- Weight without battery: 65g
Infilux IFE1 XPG-R5
Q Mini 123 XPG-R5
