burntoshine
I realize there's other threads on lube, but I have a specific question about the lube Nitecore is using...
Okay so I contacted 7777, which is where i purchased my EX10 and most recently, my D10 R2. I noticed on my D10 R2, the lubrication on the piston o-ring was different to what I'm used to. It's of blue color. Seems like sort of a pasty grease. It seems to work really well for the piston o-ring, so I asked 7777 if they knew exactly what Nitecore uses or if they could find out for me; also if they knew how I could obtain some. They just pointed me to deoxit, which they sell. Then I asked Nitecore.
Apparently they use something called Mobil XHP 222. I looked it up here. Under 'Precautions' it mentions that it is "manufactured from high quality petroleum base stocks". I was going to look into getting some for my EX10 and D10 if I could find it in smaller than 'barrel-size' quantities. I figured if that's what they use, it might be pretty decent (it seems buttery smooth to me). I've heard that petroleum is bad for o-rings. But why would Nitecore use something that's bad for the o-rings/flashlight. It doesn't say "petroleum based", it says "lithium based", but it does contain petroleum. Does anyone know anything about this stuff. Should I not be bothering with it and go with something simpler? I figure Nitecore knows what they're doing and I like how smooth it is.
...just found this: http://www.grainger.com/Grainger/items/1MUC1 $3.53 for 14.1 oz.
I've been using plumber's silicone grease (no petroleum) from lowe's for years. I tried nyogel 779ZC and it seems to add more friction to the piston o-ring and gets gummy. Should I have got the 760G nyogel instead?
I've also heard that petroleum is okay, like in this post.
Any thoughts?
Maybe I'll just stick to silicone grease....?
I might order some and test it myself. I guess the worst that is most likely to happen is I'll have to replace the o-ring.
...Forgive me if this particular product (Mobil XHP 222) has already been discussed, but a search turned up nothing for me.
Thanks!
Any thoughts?
Thanks!
