Re: Nitecore "Tiny Monster" TM11 (4x18650, 3xXM-L) Review: RUNTIMES, BEAMSHOTS, VIDEO
The likely source of your problem is cell length. I've seen some 2600mAh cells (especially small button top) that can exceed 69.0mm in height. That can cause problems in some lights with tight tolerances, including the TM11. I would recommend trying to crank the head a bit tighter, to see if that works. If not, you may have to try a difference brand of cells. :shrug:
Yes, that's just Xtar's nomenclature for their cells - they are still considered as 18650-class by everyone else.EDIT 2: I know it says 18650s but I was under the impression the only difference between 18650 and 18700 is the length.
