I'm having difficulty finding photos right now (and I'm away from home so I can't taken any) but the Millennium bezel threads are much wider diameter than the standard bezel threads.
Does this help?
Millennium top
Standard bottom
The Lamp Assembly used by the M2 is the same P60/P61 used by the 6P, and the Z32 Classic Shock Isolated Bezel. All three have standard bezel threads.
Shock Isolation does make the bezel diameter wider.
6P (1.25")
Z32 (1.36")
M2 (1.47")
The difference between the Z32 and M2 is mostly due to the far thicker bezel wall.
The new (current) M2 bezel is the same diameter as the old (pictured) M2 bezel at 1.47".
What is the Z32? Just one of the most common SureFire bezels (used by Classic SureFire WeaponLights including those of MP5 & Shotgun forends)
Seen here on a G2-YL (yellow)
However, you'll note that M3 bezel wall are not nearly as thick as the M2 bezel wall and yet it was wider still at 1.62"...
Here is a photo of a Millennium TurboHead, M3 bezel and E-Series bezel:
Here is a photo of a standard [C2] bezel, proto-type M2 bezel, pre-production M2 bezel and production M2 bezel:
There are several reasons for this difference in bezel diameter and in wall thickness but mostly its because the M3's reflector needed to be as wide as possible inside its bezel, and the M2 bezel was thickened during proto-type field-testing so it could be significantly more durable [as it was to become the bezel of the M95 - most-issued WeaponLight to the US Military. This is also why the "M2" bezel was changed a while back in order to reduce the weight - a key issued raised by users during feedback to SureFire.].
For interest here are the bezel diameters and information for the FM Series of BeamFilters:
FMx3 IR BeamFilters - Glass (I'm not sure of it's details)
FMx4 Beam Diffusers - POC's 'LSD holographic 20deg diffusion polycarbonate
FMx5 Red BeamFilters - Multi-AR coated tempered Pyrex glass
FMx6 Blue BeamFilters - Multi-AR coated tempered Pyrex glass
FMx7 BeamCovers - Hard Anodised aluminium alloy
FM1x (1.62" diameter) - "M3" Millennium Bezel, 9AN & KL6.
FM2x (2.5" diameter) - Millennium TurboHead bezel & 'KT' TurboHeads.
FM3x (1.25" diameter) - Standard "6P" bezel (tight on the G2/G3/G2Z).
FM4x (1.36"diameter) - Z32 aka Classic WeaponLight Shock Isolated Bezel.
FM6x (1.47" diameter) - M2, 8AX/8NX/L7, KL3/KL5/U2 etc
FM5x for ScoutLight (FM53 IR) (new)
FM7x for HellFighter (FM73 IR), (FM77* Amber) & (FM78* Opaque)
(*it would make more sense for these to be the other way around but I need to check that)
Al
