mdocod
CLOSED
(please continue HERE)
Odd Mods Battery Adapters
The battery adapters listed below are a marriage of semi-common fasteners with semi-complicated milled and drilled plastic parts and hand-cut copper pieces. The plastics used are primarily acetal and nylon, except where clear plastic is noted or pictured (acrylic). Milling, drilling, cutting, punching, threading, grinding and assembly operations are performed by myself with an assortment of tools in the garage.
Please Read:
Availability and pricing are listed below each product. Availability information is updated every few days or so, and should be considered up-to-date. If you have questions about availability or pricing or payment, please ask them in a response to this thread whenever it is reasonable to do so, (this will help me keep my PM box under control!). -Thank You
Product Offerings and Availability (as of 10-22-09):
Please have a look at the new 6AA adapter design below. This design premise is what all future batches of 3 abreast AA adapters will follow. I am phasing out the "for button top only" style of adapters and going to a more robust and versatile design for all future builds. As the new styles become available, any older units still in stock will have a price cut. Keep an eye out for good deals!
New Product: 3x17670 for SureFire M6 adapter. Available Here.
3AA > 1D ~3.6V, for flat top or button top cells
~12 Available (gray nylon support rods shipping now)
$26.00 each
Add $2.00 for shipment to USA/Canada for any quantity up to 4 adapters.
Add $2.75 for international shipping of 1 adapter, $0.75 for each additional adapter.
Ordering 5 or more? Contact me for large order discounts.
*Designed for use in cut-down and re-threaded "1D" length MagLite's. Actual adapter length with cells installed may vary. Compatibility with other flashlights not guaranteed. Not Stackable!
I recomend checking out CPF member wquiles here in the customs BST for cut-down mags for these...
3x14670 ~11.1V, for flat top or button top li-ion cells
This would make a nice power source for buck regulating 2-3 emitters, or running some bulbs ~10W or less with a regulator.
3 Available
$27.00 each
*Designed for use in cut-down and re-threaded MagLite's. Actual adapter length with cells installed may vary however with cells of exactly 67mm lenth, final adapter length becomes ~77mm from negative contact plate to top of positive "button" screw head. Thumb nut on tail needs an additional ~9mm of room but that rides inside the spring in most application with no interference. Not Stackable!
New Design!
6AA > 2D ~7.2V, for flat top or button top cells
The design changes and features of this 6AA adapter are plentiful:
- Excellent cell retention provided by a combination of flat brass contacts (machining texture left in-tact to improve friction) and cell retaining pocket design.
- More refined look and feel
- Easy side loading design means cells can be removed for charging without hassle
- Pack charging is also easy with included alligator jacks/wires
- Thicker Delrin end caps and intermediate spacer for better overall rigidity and deeper cell pockets
- Delrin support rods keep all components in alignment and protect the unit from damage when cells are not loaded.
- Easier tightening/loosening with thumb nut
- Positive contact closely resembles "D" cell button top for proper contact pressure with mag switch.
- Compatible with any type of AA or 14500 size cell. (even those pesky ones that are a little thicker than normal). Button top or Flat top works fine.
25 Available
$34.00 each
Add $3.50 for shipment to USA/Canada for any quantity up to 4 adapters.
Add $5.00 for international shipping of up to 2 adapters, $1.50 for each additional adapter.
*Designed for use in 2D size MagLite's for custom modifications. Actual adapter length with cells installed may exceed the length of 2D cells slightly, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with both button top and flat top cells.
9AA > 3D ~10.8V, for flat top or button top cells
~8 Available for shipment by August 4th 2009
Normally $36.00 each
Price Reduced: $27.00 EACH
Add $3.00 for shipment to USA/Canada for any quantity up to 4 adapters.
Add $4.00 for international shipping of 1 adapter, $1.25 for each additional adapter.
*Designed for use in 3D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 3D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable!Adapter shown/sold here can be used with both button top and flat top cells.
12AA > 4D ~14.4V, for button top cells
~7 Available
Add $4.00 for shipment to USA/Canada for any quantity up to 4 adapters.
Add $5.00 for international shipping of 1 adapter, $1.50 for each additional adapter.
*Designed for use in 4D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 4D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with button top cells only.
12AA > 4D ~14.4V, for flat top or button top cells
~9 Available for shipment by August 4th 2009
Normally $42.00 each
Price Reduced: $31.00 EACH
*Designed for use in 4D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 4D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with both button top and flat top cells.
15AA > 5D ~18V, for button top cells
~2 Available
Normally $40.00 each
Price Reduced: $30.00 EACH
Add $5.00 for international shipping of 1 adapter, $1.75 for each additional adapter.
*Designed for use in 5D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 5D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with button top cells only.
15AA > 5D ~18V, for flat top or button top cells
~1 Available
Normally $48.00 each
Price Reduced: $36.00 EACH
*Designed for use in 5D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 5D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with both button top and flat top cells.
18AA >6D ~21.6V, for button top cells
SOLD OUT! (Design change in the works)
$44.00 each
Add $5.00 for shipment to USA/Canada for any quantity up to 4 adapters.
Add $6.00 for international shipping of 1 adapter, $2.00 for each additional adapter.
*Designed for use in 6D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 6D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with button top cells only.
18AA > 6D ~21.6V, for flat top or button top cells
~2 Available
Normally $54.00 each
Price Reduced: $42.00 EACH
*Designed for use in 6D size MagLite's for custom modifications. Actual adapter length with cells installed vary slightly from the length of 6D cells, but has been tested to work in MagLite Body's with the stock spring installed. Not Stackable! Adapter shown/sold here can be used with both button top and flat top cells.
future plans...
Various side-by-side multi-18650 and 18500 adapters for dual/quad bored mags are definitely on the list, but I don't have any guesstimate for a time frame at this time.
3x17670 PhD project regulated adapters for M6 are on the plate. We are still committed to this project.
I will be working on 4xAA abreast adapters for mags eventually. I've tried a prototype end-cap with good success and intend to make this a realty. Time frame is unknown.
That pesky fine print stuff... "lawyer talk" [PLEASE READ BEFORE ORDERING]
I'm not a lawyer, so I'll use english instead :)
I sell these adapters with the assumption that the receiving party has an understanding of electronic circuits and the dangers they could potentially present. But for obvious liability reasons, these adapters do not come with any batteries. Beginners in the realm of modifying flashlights should feel free to ask questions in this thread, or in one of the many appropriate places on this forum to build up a proper understanding of the modifications intended before attempting to modify a flashlight with an after-market adapter. Use of these adapters may void warranties of some flashlights. Please take responsibility and understand the risks.
Payment Instructions:
Send Paypal to [email protected]
Only send payment for adapters listed with availability above. (with enough quantity remaining)
Please make note that you have sent payment and what for in this thread. I will generally go to the post office 1 or 2 times per week between Monday and Thursday.
Please include CPF username and order details in paypal notes.
Thank You for Looking!
I look forward to your order,
Cheers!
Eric
Previous Thread references:
http://www.candlepowerforums.com/vb/showthread.php?t=195976
http://www.candlepowerforums.com/vb/showthread.php?p=2346677#post2346677
http://www.candlepowerforums.com/vb/showthread.php?t=204701
