LED Zeppelin
JS, thanks for doing the 2nd run, count me in. Email sent.
Don't forget about the people that will likely want 2 packs.js said:...Thus if interest continues at this level, there will be more than 30 people who want packs...
...Frankly, I suspect that interest will slack off a bit before Feb. and that a lot of people will get caught up in the latest and greatest this or that, or buy a gun or a knife or a computer instead. So with any luck this may become a non-issue.
In any case, thanks everyone for your enthusiasm and interest! I am truly honored by it.
slind1 said:Hi Jim,
I also would like to be included in the 2nd run. I've sent an email to the 'notify' list as well.
Kind regards,
Steve
js said:OK guys. This is getting CRAZY! CRAZY with a capital "K".
What the heck is going on here?
[/b]
andrewwynn said:I might be able to remove some heat from you JS..
See this thread
There is a very good chane that by feb or march i could make a production run of whatever viable solutions for M6 i come up with.. and they will be something like a 10.8V pack that'll run the 1185 or 1331 WA bulb so you don't have to spend so much on SF bulbs... or a 7.2V pack that will have a switch for the HOLA or LOLA..
Whatever solution i come up with it will be geared around making the production as absolutely simple as possible as prirority #1.. so that a single person could make numerous quantities per day.
Obviously there is tremendous demand for 'fixing' the M6 being such an awesome light with such a craptacular powerplant, so once the M6 fix i have is done.. probably mid Jan or something I will of course post a thread, to see how many aren't covered by the M6-R solution that might still need a fix.
I haven't seen the details of the M6-R... guessing it's a 7.2V NiMH pack with an LDO to keep the voltage at 6.1 for hola.. or even more clever.. 7.2V max with 4.9A max current so that you can swap lamps w/o changing any settings... wow that's a cool idea.. that's even better than using a switch.
Not trying to steal any thunder, seriously saying i might be able to help share the load of demand for M6 soluitions that make sense.
-awr
