js
OK. Links:
The SF M6-R part 1 (original thread)
Brightnorm's review
The summary thread
And there are others, but you should find the links within the threads posted above.
unnerv,
Not a problem. But you should understand that building an M6-R is far more difficult than just making up a pack and connecting some wires to a regulator. When I post the construction details thread you will see what I mean, but just for starters you have to decide on how you are going to bring the negative output from the LVR, and the positive output from the battery pack (the LVR just passes the positive--only the negative is switched) and have them mate electrically and mechanically with the top and bottom springs inside the M6. Also, you need to figure out how in the world you are also going to connect (within the same pack) directly to the plus and minus contacts of the pack itself. It is a wiring nightmare.
And that's not all! The springs are pretty agressive little guys and will cut into most anything. I eneded up having to go to silver BRAZE on top of 1/16" copper sheet end caps. But not just anything can cut 1/16" copper into rounded triangles without deforming the plane of the triangle.
You know, I really hope at least one person tries to build his or her own pack. I would absolutely love to talk on the phone and commiserate about all the difficulties and catastrophes and frustrations involved in making an M6-R pack. That would be so great!
So, I'm not trying to scare you away from doing it, but definitely keep an eye out for the construction details thread so you can think through exactly how you are going to duplicate my various steps and procedures before you commit to dropping no small amount of money on two LVR3I's set for the MN21 HOLA driven by 9 NiMH cells.
Brightnorm's review
The summary thread
unnerv,
