andrewwynn
I'm definitely a character, yeah i do know it, please don't be offended.. if so.. please tell me.. definitely not intended... i do get loopy at times though.
1.. strongly beg to differ.. a light that costs $25-100/hr to operate when it should costs pennies.. has a very big problem, that should be solved.. that is my point about fixing.
2... MB20... if talking about the holder.. that is an asbolute work of art.. i've not exactly figured out what order they wired them up but it's a beautiful piece of work.. the one in the light i have did not have enough spring tension but the design is such it took 1 minute to fix that.. 3 of the springs did not hold the batteries very tight.. but they are solid metal not coiled springs like the ones we melt in our AA adapters. I was talking about using primary 123cells at 4.9A.. that's a foolish thing, plain and simple.. primary lithium cells are 1.3AH cells.. pushing them to 3.8C is borderline crazy. i'm surprised they don't explode.. (glad they don't explode, just surprised). Consider that... at 4.9A say.. for 20 minutes.. that's 816mAH.. from 1300mAH cells.. that means that 40% of the stored energy in the cells is thrown out by pulling the current out so fast.
[edit].. my goof.. i know and knew that the cells are series-parallel.. but goofed and forgot to divide by two... the reality is that 2.45A is only 1.88C which though high.. as JS very wisely points out below..the most POWER is obtained from any power source at 50% efficiency.. reminding me of electronics school days.. so it's a very logical conclusion theirfore to push the batteries that hard to maximize power transfer at the (extreme) cost of.. well cost.. and also efficiency.. it's a valuable and understandable tradeoff.. without that math error .. i'm sure much of the following debate would have been avoided.. sorry folks... it was pretty late.
2a.. since with virtually NO modification you can fit NINE cells of the same size in.. it could be a simple series-parallel solution which would bring the current drain per stack down tremendously but of course would probably blow the bulb.. it never fails to amaze me how much space inside a battery compartment is NOT BATTERIES.. like the mag.. which always looks like it's 1 more cell than it is because of how big the switch mechanism is and battery spring is.
3... i've not had any luck searching cpf since the changover.. example... trying to find the runtime output graph of the USL.. etc.. it's very frustrating.. Not sure that a preview of exactly what the pack was/is/does would make any diff. for a post but you are correct about 'good form'... mea culpa.
4. LOTC? Does that mean either the holder for the cells which i don't recommend modifying.. or the bulb holder? I believe that the SF bulbs are worth what they cost.. that quite likley it's not possible to come up with a better solution for putting in the M6.. but when i run the numbers and it is feasible to put an 1185 bulb into an M6.. and run it 2x as long as the MN21.. I dunno.. to me, that's interesting and should be followed up on.. it may well be a total bust in which case im completely prepared to work on the add'l plan of putting the regulator into the light between the battery pack and the bulb so you can use standard bulbs and blamo.. very cool note about the other bulb that works at the same voltage as the MN21.. very cool.
5... i agree on the MN21.. haven't seen the MN20.. the problem is not the bulb, the light, but the power plant.. if that wasn't the case this thread wouldn't exist.
I have 'heard' about the M6-R.. and i'm blown away that there aren't more like it.. it's awesome for you to pave the way.. i can only be a copy cat now
I like the philosophy you present.. quality over quantity... Why'd you think i'm so interested in those ring-potted lamps!
-awr
-awr
