The PWM strobe effect is significantly more noticeable in the M30 than any other flashlight in my collection. Here are a few beamshots of an overhead ceiling fan, spinning at its lowest setting. Note: The strobe effect is only noticeable in the low and medium modes, not the high mode. (Click on thumbnails to enlarge.)
M30 (low) .......................M30 (medium) ................M30 (high) ................. Note: Subtle (imperceptible by naked eye) PWM on
1/30 sec, F3.5, ISO 100
.....1/30 sec, F3.5, ISO 100
.....1/30 sec,
F8.0, ISO 100
. high, when compared with other flashlight photos.
L2D CE (high) ..................L2D CE (turbo)
P3D Rebel 100 (high) .......P3D Rebel 100 (turbo)
ED-P72 (low) ..................ED-P72 (medium) ............ED-P72 (high)
.....1/30 sec,
F8.0 ISO 100
.......1/30 sec,
F8.0, ISO 100
I'm not particularly sensitive to PWM issues, but I have to say that the strobe effect on low and medium is quite pronounced. I would guess that the darker the ambient lighting conditions, the longer one uses the light, and the more intensive the visual task; the more irritating the problem would be. I can understand how Monkeyboy found the beam very disconcerting on his hike in the woods. It probably would have driven me bonkers.
(Well, that's what backup lights are for, right? :tinfoil
I tried using the diffuser, in the hopes that the more diffuse beam would limit the staccato effect. However, the diffuser did nothing to mollify the strobing. :sigh:
EDIT:
Correction. I forgot about one light that I have with a similar PWM issue - my L0D CE. On low, the strobe rate looks about the same as the M30's. On medium, the LOD's PWM frequency is higher (better), slightly less noticeable, but still present. Not a problem on high.
The L0D's PWM doesn't bother me for a few reasons: (a) It's generally used for very short periods of time, 30 seconds to 2 minutes. (b) It's generally used for very close-in tasks, under 5 feet, with nothing moving very quickly. (c) I generally don't pan a scene in low or medium. If I pan a scene, I have the L0D on high. (d) The situations where I most use the light is being plunged into darkness after being in the light, i.e., my eyes are not night-adapted. They are therefore less sensitive to beam peculiarities.
