cmassicotte
I have couple of the "old" style Mini Mags (with 4 holes in the plastic do not remove thingy), and I would like to convert them to LED.
I have a bunch of questions about the process.
The Opalec is regulated and the Inretech is not. This means, if I have figured it out correctly, that the Opalec will put out the same amount of light for about 10 hours - and then start to decline in output. The Inretech starts out at a higher out put and has a steady decline over an extened amount of time.
My questions:
1) Can I even use an Opalec? For that matter, can I use an Inretech with the old model?
2) Given that the Inretech starts out brighter than the Opalec, has anyone done a study of how long it takes for the Inretech to reach the regulated light output of the Opalec?
2a) Does anyone know what the light output of the Inretech is at 10 hours? It would seem to me that this info would enable one to get an idea of how the two mods compare.
3) Has anyone done a head to head comparison between the two and documented the results - specifically about light output over time - and if so, where can I find them.
4) I believe I read some where that the inretech mod actually only requires one to to pull and replace the Mini Mag bulb - with the option of replacing the lens if needed. Is this true?
It would seem to me that the idea of regulated power, thus keeping the same output for a certain know period is a very good thing. However, if the point at which the unregulated light reaches the output of the regulated light is somewhat near the end of the regulated output time, then it would make sense to get the initially brighter light.
I hope the above questions and comment makes sense. In any event, what ever info you can give me to help me make the decision will be appreciated.
Thanks,
Chuck
My questions:
Thanks,
Chuck
