I'm just curious what other people's opinions are on multi-stage lighting. Is it just gimicky? Is it poorly implemented as well?
My opinion, I could see wanting to have a 2 or 3 stage light, but 5 to 7? is that a little much, who needs strobe mode?
Most of these multi-stage lights seem poorly implemented too, having to click your way through the stages every time you turn the light on in order to get to the desired stage seems wrong from an end user's perspective. All of these lights, the expensive ones anyways, should have a dial on the light (something like turning the end cap tighter) so that you can choose your stage before the light is even turned on, and it will always stay in that stage until you move the dial. Some start out in the wrong stage too. Why start on low? the order should be medium->low->high (if a dial's not possible).
Any thoughts? Am I the only one who thinks multi-stage flashlights aren't implemented right?
