Yes, probably my sockets
Here is my order detail:
Onelevel Mode for all 3
Order:
- Quantity of Regulators: 3
-- Standard Model Regulator:3
- Quantity of User Supplied Sockets:3
- Quantity of Programming Adapters: 1
- Shipping: 9
- Sales Tax: 0
Payment (do not pay until directed):
- Total Amount: 3x97 + 12 + 9 = $312
- Paid via PayPal on 11 July 2009
- make sure to include your CPF Id and posting number in this thread in your PayPal
Regulator Number (for each regulator in multi-regulator orders): 1
Regulator Model: (standard)
Bulb Data:
- Bulb Type (manufacturer, model): Osram 64642
-- Note that if the bulb information is given, and the voltages are not specified, we will use the default values for this bulb.
- Bulb Height
Max Overall Length (MOL) 1.969 in (50.0 mm)
Bulb Diameter 0.433 in (11.0 mm)
Light Center Length (LCL) 1.260 in (32.0 mm)
Order Codes 64642 HLX
- Maximum Bulb Voltage (RMS full output) (optional): 26.0
- Minimum Bulb Voltage (RMS fully dimmed) (optional): 10
- Locked Out Basic flashlight Bulb Voltage (RMS) (optional): 15
Battery Management: (will compute from Chemistry, Ncells if not specified)
- Battery Chemistry: LiMn
- Number of Cells: 8
Note that if the voltages are not given we will use the default values for the battery chemistry and number of cells specified.
- Maximum Battery Voltage: (optional)
- Nominal Battery Voltage: (optional)
- Minimum Battery Voltage: 3.6 each
Socket:
Basic, Osram Socket Upgrade, User Provided (specify): Kiu provided
Other Features: (indicate if NOT wanted or specify value)
- Click to Memory Level (if not then Max)
- Double click to Max Voltage
- Press from off to Min voltage
- Press from on to Ramp - alternates up/down (ramping feature)
- Triple click to Mid Voltage (halfway between minimum and maximum voltage)
- Quad click to alternate between ramp and 7 level step
- Five clicks to Lockout
- Lockout Basic Flashlight mode (click on/off low power only)
- Fast Soft Start: 100mS – No – slower 3-500 ms
- Temperature Brightness Reduction at: 50C (shutdown takes place approx 10C hotter)
- No Activity Shutdown Timer in Minutes: NOT
Regulator Number (for each regulator in multi-regulator orders): 2
Bulb Data:
- Bulb Type (manufacturer, model): WA 1185
- Bulb Height (default is 14.3mm for WA1185 in standard reflector):
- Maximum Bulb Voltage (RMS full output) (optional): 11.0
- Minimum Bulb Voltage (RMS fully dimmed) (optional): 4
- Locked Out Basic flashlight Bulb Voltage (RMS) (optional): 8
- Battery Chemistry: Nimh
- Number of Cells: 12
Socket:
Regulator Number (for each regulator in multi-regulator orders): 3
Bulb Data:
- Bulb Type (manufacturer, model): WA 1331
Socket:
