The benefit of NiMH including Eneloop is its ability to
raesonably sustain high current discharge; Alk D is not designed for high current discharge. Notice in the datasheet Energizer only tested
Alk D at 500mA in comparison to
4000mA NiMH AA or
1000mA Lithium E2 AA.
- 3 Alk D capacity would be unpredictably low, note that at 25mA it holds 21,000mAh but at 500mA it holds only 11,000mAh; I have no idea how much it holds at higher current but I don't like the trend.
I have 6D M@g with BuckPuck pushing 1A through Q5; with 6 Alk D I see 500mA * 9V = 4.5W, 5 Alk D I see 600mA * 7.5V = 4.5W, 4 Alk D I see 800mA * 6V = 4.8W (BuckPuck efficiency went down), I can't test with fewer cells because BuckPuck minimum input is 5V.
2000mAh NiMH will give you at least 1 hour in practical use;
the datasheet infers 1.5 hour runtime but notice the voltage sag; your circuit will draw more than 1500mA as the voltage drops (just like my BuckPuck setup).
I just did a
naughty test, a fresh Alk D could actually push almost 9A, yes 9000mA
Not so fresh Alk D could only push 2A. I wouldn't dare to do this with LiIon fearing explosion but Alk is safe
I have no idea what the voltage was because I only have 1 DMM, theoretically it's near-zero volt because the DMM would have little resistance.
So in theory 3 Alk D should be able to sustain 1500mA draw but nobody know what sort of capacity it would have; note that at the capacity is halved when you increase the discharge from 25mA to 500mA; I can't imagine 1500mA because it's too far from the specification.
To get the most of your 3 D M@g body, I suggest you use 3 NiMH D, or 9 Eneloop paralel holder (3 * 3)
