TakingVacation
- Joined
- Nov 4, 2008
- Messages
- 7
I've got one of those on order, but I think the problem is going to be that it won't get you to 2.8A on a 3D Nimh cells. I'm having trouble getting 3D's to get me to the needed Vf on the DSWOJ's that I got from LiteMania. They have a great color to them, but may be at the top end of the BIN at 3.75 volts. So when the batteries come of the charger they are at 1.4 x 3 = 4.2 and when you hit the switch on the mag (cut and direct wired to accomodate the heat sink that also came from LiteMania) the voltage drops about 10% = ~3.75. Shortly, the voltage on the batteries drop closer to 1.25 volts = 3.75 volts leaving the voltage at the emitter at 3.36 or so and the DMM showing about 1632ma so the output really falls off with the Direct Drive (DD) Nimh. I'm running the same setup on a 2D with 3C's in a 1.25" PVC sleeve on another Mag with the same issue.
I think I have a few choices, and maybe you as well:
Run 4C's in a 3D body - cut the tailswitch down, and either add a 1ohm resistor or drop the voltage with some type of circuit board down to 2.8 (either KD or DX).
-Or-
Go out and spend the money on a boost driver
-Or-
Spend the money on a I Bin with lower forward voltage where the P7 will draw more amps at a lower voltage
-Or-
Get about and equal result on a DD Li-ion and having to deal with either cutting down the maglite (which would be nice) or putting in a dummy cell or going with 2 Li-ions and using a circuit to drop the voltage
-Or-
Live with the lower voltage and amps and lower output but gain longer run times and have about 60% of the max brightness
In the end, it comes down to how many dollars to spend to get the J Bin voltage optimized on a 3D setup.
By the way, both my 3D and 3C are almost exactly the same with voltage and amp measurements. I do think the 3C 5000 Mah Tenergies actually seem to hold their initial voltage longer than the Titanium 12000 Mah D-cells
I'm happy with the output now, as they are twice as bright as my 240 lumen maxed out R2 LED light and way brighter than anything off the shelf, but like most that are now addicted to this stuff - I want more light and things to run near the max of their potential.
This is my take on things, but would really like to get some direction on another alternative that might help squeeze out a few more Volts/amps from a 3D or 3C setup that are DD on the J bins P7's....
-Or-
-Or-
-Or-
-Or-
