IcantC
- Joined
- Oct 12, 2007
- Messages
- 920
Thanks guys, I have the cam cut off all the way. I used the sputtered reflector, but it kills the throw. It did give great flood, I reverted to smooth and do not mind the hole.
Try less sputter or a different technique. If your sputtered reflector is making the beam flood then it is sputtered way too much. Nice thing about sputtering, once you get the technique down, you can sputter just enough to smooth out the beam without a very large loss in throw.
Thats were i got mine from wayne im happy with it i just want to get a better beam out of it.I know someone will find or make a better reflector for it and when they do i will buy it.:thumbsup:
I've heard from one of my suppliers that this reflector, originally designed for the OSTAR 6-die LED works pretty nicely with the P7, once the opening is expanded a tad for the P7's dome diameter.
The size is roughly 22.85mm in diameter and 15.5mm tall:
I've asked for a quote and will most likely get some, once I get the pricing.
Thanks im hoping to find a reflector that smooths out the beem and improves the throw to.I think it looses throw because the gap is not butted up to the emmiter.I have been thinking of something i could put in there to but up against the reflector like a little mirror or something like the fenix lights have so there is no gap between the emitter and the reflector might loose the focusability but who care if it significantly improves throw and beem smoothness.us cpfers need to figure this out i think this has way more potential.:thumbsupf course i posted this before i saw the dx reflector should have read down a little further looks good just wish it screwd all the way down.think i will try it.Husky 20, I got my notice from Wayne today, likely i'll get mine in by saturday. I've got both an M2 camless SMO and an LOP from Modamag as sold at The Sandwich Shoppe reamed to 0.625". With luck they will fit as is or with only minor fitting. They are narrower than the stock reflectors which should trade back some flood for throw when using the LOP. If the LOP isn't adequate, I'll order an M2 MOP and see how it works. StefanFS in another thread said the KD MOP smoothed his beam but cut the throw significantly. However, the KD's medium orange peal looks pretty heavy compared to the pictures I've seen of the M2 MOP. I'll keep you posted. The M2's aren't cheap, but my waistline could stand to skip a lunch or three.
How well does the Deal Extreme reflector throw compared to the standard smooth maglite reflector? How does the it compare in side spill?Pics...
Deal Extreme P7 reflector (SKU12229).
The bezel does not screw all the way down.
Quick beam shot. About 1.5m from ceiling. Camera on AUTO.
I haven't used the standard smooth reflector, only the Fivemega LOP and this DX MOP. The throw is quite reduced compared to the FM one and the spill is quite blinding which stops you from seeing the throw properly.
It's definitely not for throw, just a nice smooth beam.
I figured that. What kind of throw does it have? I'm guessing it's putting out quite a bit of light, but, in your opinion, at what distance does it start to lose it usefulness?I haven't used the standard smooth reflector, only the Fivemega LOP and this DX MOP. The throw is quite reduced compared to the FM one and the spill is quite blinding which stops you from seeing the throw properly.
