Hi All,
Apologies if my questions seem trivial, I just wanted to check a few things before I spend some money.
I'm thinking of building a custom light for mountain biking, I am thinking of getting a P7 (http://www.dealextreme.com/details.dx/sku.12721) from DX,
would the driver they have - (http://www.dealextreme.com/details.dx/sku.20329) be ok with the following setup -
- I'm thinking of running 2 chains of (4 AA cells in series) in parallel, which would give about 4-5volt. Would this be an acceptable approach?
- I'm looking for a run time of about 2 hours. (i'm open to ideas).
- The last charger I made years ago was a simple NiCad one, how would I go about charging the custom NiMH or Lithium pack? - I'm guessing it is not straight forward - could someone point me in the right direction please? (is it best to resort to removable cells and use an off the shelf charger?
My last questions surrounds heat dissipation from the driver - As it has two boards, I am assuming this only needs mounting by the base - how would you mount the driver securely? Thermal grease doesn't look like it would work on its own?
http://www1.dealextreme.com/productimages/sku_20329_3.jpg
[Hotlinked image replaced by link - please read Rule 3. - DM51]
Is there anything else I need or should know about?
Thanks in advance.
Lee
Thanks in advance.
Lee
