georges80
Hi Folks,
if some of you have been frequenting the bike subforum here on CPF you would have seen the hipFlex development that is ongoing.
I have taken the hipFlex buck driver core and made a 'dumb' driver - the hipCC. I received production PCB's today to build up a test unit and it all works nicely just as it does integrated into hipFlex.
This is a buck driver that can run from 4.5V to 24V input and drive from 1 to 5 P7 or MC-E (in 4P) LEDs. It will be set to a nominal 2.8A output but by changing sense resistors it can be adjusted up to 3A as can be seen in the pictures below.
The board is 1.1" in diameter and single sided so the bottom can be mounted to a heatsink. I will be supplying a piece of thermal pad material (nominal 1mm thick) to use to interface from the PCB to the heatsink. There are 2 mounting holes to enable screwing the board down to a heatsink and 'squeezing' the thermal pad material.
Efficiency will be similar to that posted for hipFlex and the curves are posted below.
Reverse polarity is provided on board. Total headroom at 2.8A from battery in to Vf out is 0.5V (so very low voltage drop across the driver).
A PWM input is provided and I'll be documenting that on my website as I get the driver ready for shipping within a week or so.
I have bench tested the driver for 2+ hours with 3 P7's at 2.8A and with thermal pad material to a heatsink the driver reached around 30C (~20C ambient). I have tested 5 P7's for over an hour and it was around 35C.
So, picture of the top of the board:
and of the bottom of the board. The silvery areas with lots of vias is to optimize the heat transfer through the board from the main power components.
and a picture of the driver fired up and pumping 3A through 3 series connected P7's (with some paper to 'shade' the camera).
and a measured efficiency plot of hipFlex that is also applicable to hipCC. Note that these curves are from the hipFlex proto that used a schottky for reverse polarity protection so is a hair lower than the production hipFlex and hipCC.
cheers,
george.
cheers,
george.
