I imagine a lot of us are thinking about what the P7 can do and how we can use it. I have a couple of specific questions that I'm hoping some more knowledgeable members would have a feel for. The first is, in a given reflector, what will the beam be like compare to a P4 or a Cree. For example, I have an Ultrafire C2 Q5 that has a decent sized reflector. In fact it has a flat area at the base of the reflector with a small hole for the Q5. That flat area looks to be about 1/2 inch in diameter--intriguingly close to the size a P7 would need. The C2 is fairly throwy, with the Q5 centered at the bottom of the reflector. If a P7 was put in there, can anyone predict what the beam would look like.
Second, shouldn't this be a more efficient emitter than what is currently out there at comparable lumen levels? For example, if I only want, say 250 lumens, I'm extrapolating it would take about 1000mA (at ~3.15v). A C bin might even take less. This should significantly be better than a Q5, right? Would it also be cooler at that low (for a p7) output?
Thanks very much for your thoughts!
