I'm intrigued by the possibility of getting a high output HID for a reasonable price simply by adding HID bulb and ballast to a conventional halogen automotive light (or a handheld searchlight with an automotive bulb). It is very tempting to assume it would be as simple as replacing say, the stock H1 halogen bulb with a HID H1 kit. Specifically, I'm looking for either H1 or H4 HID bulb that isn't the cold, blue/white color, but more like 4300 K. And - most likely I'll try to scoop out something from Ebay.
But what traps are there to look out for? Am I just overly pessimistic, or are there some traps here, such as different flavors of H1 / H4 bulbs, different placement of the bright stuff (not in focus), quality issues and so forth. I assume there are some obscure codes that describes such things - what are they?
Also - what is the typical operating voltage range of the ballast? I've heard 12-16 volts, but how far down can the voltage drop before there is a problem powering the light?
What is the real world power consumption of say, a 35w HID? I know there will be some high amperage startup draws, but given there must be some losses in the ballast how much power must I supply after the warmup time? 40-50 watt?
