Please help me ID this mystery driver...
AlexGT
Houston, Texas
Hi all!
I had ordered a 7135 AMC driver about a year ago and got another driver instead which I can't find the specs for it, I would like to know what voltage to feed it and what is the output so I can experiment with it in a custom project.
I looked on DX and Kaidomain but nothing (Don't remember from who I ordered from)
It Looks similar to this one but is not the same.
http://www.dealextreme.com/details.dx/sku.10084
or this other one but not the same either
http://www.dealextreme.com/details.dx/sku.7425
Here are some pictures of it, Can someone recognize it? What is it? Buck? Boost? specs?
Thanks!
AlexGT
http://www.dealextreme.com/details.dx/sku.7302
1.5V step up circuitry for Cree, SSC, and emitters with similar power specs- Manufacturer pre-assembled, no more wires to solder between the two boards (except the usual two red/black emitter connection wires)
- Manufacturer rated maximum input voltage: 1.5V (0.9V cut-off)
- Manufacturer rated current output: 500mA (when input current <= 2A)
- Can be powered by a single 1.2V / 1.5V NiMH or Alkaline AA battery
- Plug and play state circuitry offers 5-modes as soon as you install this circuit board into your light
- Works with both clicky siwtches and twisty switches
- Mode cycle: Hi 100% > Mid 35% > Lo 10% > Strobe > SOS
Thanks kiksul08!
I just installed it on a Romisen G2 / Q5 and it works very good, it looks brighter than the stock one, But it appears it is only one mode, maybe I messed it up a bit after filing.
Thanks!
AlexGT
