Please rate these D's
gratewhitehuntr
Right behind you with a 6D Mag623 !!
I'm building a ROP "flash-club" on a 6 D Mag.
I ordered these batteries but they are on backorder so I have time to cancel if I get lots of "nays" and "good god man... NO!" or other negative comments concerning the brand.
http://www.sterlingtek.com/nimdcelbat2d.html
I had read that cells with a lower capacity often have a higher discharge rate, but have no idea how to tell if these fall into that group.
If they are good then it seems like a great price. No?
Yes, this is a newb question.
Yes, I tried the search, this search function is suckin. :oops:
It was probably from ~2 years ago. I don't remember the exact thread name but someone tested the powerex to be right at 11,000 consistently & the 12,000 CTA was all over the charts, some at 10,500 & some even lower. If you read a lot of archives you'll see that the powerex is in high regard for being the capacity that they claim. I also remember the person who did the testing say that the powerex 11,000 was also much heavier that the CTA 12,000.
in the same price range you can get 10AH tenergies or powerizers, which for the money aren't terrible. They can handle an ROP lamp without even breaking a sweat.
I also have several powerizers, which you are right, they aren't bad for the price but when depleted they charge up quicker in the MH-C808M charger than the higher capacity cells, side-by-side which prove they have lower capacity.
Ok, well..... thanks for the replies but most aren't about THESE cells.
Let me try this in a different direction.
Since this is a 6D Mag, it would also hold 12 - 1/2 D's http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3775
and I could make
Mac's legendary Torch which is of Uber-Quality, and has the switch in the tailcap
He was getting 10 mins from 1400 mah cells so with 3500 mah cells I should get at least 20 mins right??
What I am trying to say here folks is that I don't want to spend
" the most for the best"
because I may decide that the ROP isn't enough and move on to bigger and brighter things and sell them off to some guys I work with or put them in a Q5 3-D Mag, or whatever.
So let me ask this question again, perhaps in a more direct manner.
Are these cells crap or will they work just fine?
(by crap I am referring to something akin to the "Ultrafire" L-ion that just "pooped" brown stuff inside my WF500 on a 6 min run)
btw, how do I get so I can post attachments? Donate?
man have I got a (clean) picture for all you dirty thinkers !!! :naughty:
actually, in most cases, the 1/2D cells are not actually a true 1/2D size, so you can't fit 2 in the space of 1 D... the 1/2Ds listed on the powerizer site are 36mm long, a regular D is 60mm long... so a 6D mag has room for about 36cm worth of cells, or about 10 1/2D cells, not 12. funny how that works eh?
