zband
I revieved this cheap charger from the battery station a while ago
pic here : http://www.alibaba.com/product-free/11159507/Cr123a_Battery_Charger/showimage.html
tem# : PH-123A-A
Input: 12V D.C 250mA
Output: 4. 2V D.C 360mA
Characteristic:
1. Suitable for 2pcs RCR123A Li-ion battery
2. Charge with constant current and voltage
3. LED indicator
Red led=batteries are properly charging
Red LED turn to green=batteries are fully charged
Green LED =power is on
if there is no batteries be detected in the battery compartment
Car adapter available (optional)
Dimension: 84 (L) x 46 (W) x 30 (H) mm
Weight approx: 50g
I did a test using my maha 777 plus on an unprotectected rcr123 battery - it cut off at 4.29V. Reading other posts apparently this is too high for a lithium ion battery. So I drained this battery and tried to charge on the cheap charger above, and it cut off at 4.19 volts - a better number.
I have made an investment in a couple 18650 protected AW's and would like to know would it be safer to charge them on the cheaper charger, even thought this charger was designed for rcr123 batteries?
tem# : PH-123A-A
Characteristic:
3. LED indicator
Weight approx: 50g
