Hello all-
I'm looking for some recommendations on a power connector to use inside of flashlight mods. Something that has two pins / connectors (+ and -) and I can use between the Mag swith and the Shark driver / heatsink. I use anywhere from 18AWG to 26AWG wire and realize the wire sizes use different connectors, but I'm thinking that one side of the connector (i.e. female) is wired to the mag switch and the male connector is wired to the Shark driver. Once you install the Mag head / heatsink / Shark in the Mag body, you could drop the switch a bit, pull out the male and female connectors and mate them and then reposition the switch. The intent would be to a) prevent the wires from twisting when you install the PES series heatsinks and Mag head and b) to make it possible to quickly interchange different Mag heads...
Now, I'm being really lazy but if someone were to recommend the connector with teflon wire already attached that would be even better!
